1956 plymouth belvedere: need measurements of trim pattern
jerrybev
Posted 2017-08-30 2:02 AM (#547333)
Subject: 1956 plymouth belvedere: need measurements of trim pattern
10010010010025
hi
For 56 plymouth belvedere 4 door sedan, I need to ask someone to measure the smaller insert pieces on the front seat, rear seat, and on back side of front seats, which are sewn to the aztec pattern, and send them to me.
My upholsterer says they cannot cut and sew the fabric correctly without the measurements. Any questions give me an email or call me at 336-749-5922.
thank you
jerry whitfield
winston salem N.Carolina
(=1956plymouthfrontseat.jpg)
Attachments =1956plymouthfrontseat.jpg (21KB - 49 downloads)
60 dart
Posted 2017-08-30 4:35 AM (#547338 - in reply to #547333)
Subject: Re: 1956 plymouth belvedere: need measurements of trim pattern
50002000100010010010010025
looks like you could count pattern lines from the photo to get a near perfect measurements if nothing else -------------------------------------------------later
jerrybev
Posted 2017-08-30 7:39 PM (#547382 - in reply to #547333)
10010010010025
hi
thanks for the courteous reply. How can I estimate the width of the insert at the top of the insert and the width of the insert at the bottom?
Do you know the height of each of the pleats in the inserts? If so, I could count the number of pleats to get a guess of height.
sincerely
Jerry Whitfield
winston salem NC
Posted 2017-08-30 7:55 PM (#547383 - in reply to #547338)
20001000500100252525
Looks like the top of the white bit in the front seat back lines up with the top of the lower white bit on the door panels.
(LiningUp56PlymouthSeatInserts.jpg)
Attachments LiningUp56PlymouthSeatInserts.jpg (39KB - 53 downloads)
Greg P.
Posted 2017-08-30 9:26 PM (#547388 - in reply to #547333)
Subject: RE: 1956 plymouth belvedere: need measurements of trim pattern
5001001002525
I hope someone will provide an actual measurement, as that would be the best way.
In the meantime, this photo has slightly better contrast. From what I can see, the gray insert is:
7 Aztec blocks wide at the top
8.5 Aztec blocks wide at the bottom (The diagonal seems to cross one and a half columns of blocks)
10.5 pleats tall
Not sure if that is helpful, but I'd think it would get you close enough.
Very cool fabric pattern by the way!
Edited by Greg P. 2017-08-30 9:35 PM
(56 ply seat.jpg)
(56 ply seat zoom.jpg)
(56 ply REAR seat.jpg)
Attachments 56 ply seat.jpg (101KB - 51 downloads)
Attachments 56 ply seat zoom.jpg (118KB - 59 downloads)
Attachments 56 ply REAR seat.jpg (105KB - 39 downloads)
Posted 2017-08-30 10:21 PM (#547394 - in reply to #547388)
20002000500100100
Greg P. - 2017-08-30 6:26 PM
10.5 pleats tall
10.5 pleats or 6 Aztec blocks tall. Nice job guys, that was great. And the full bottom seat width is 11 Aztec blocks. That can give you a measurement value if you don't have the fabric on hand to measure how big an Aztec block is.
jerrybev
Posted 2017-08-31 10:25 AM (#547415 - in reply to #547383)
10010010010025
hi
thank you for the good pictures.
I do not have any Aztec fabric. I am using different fabric but want the inserts to be the proper size, on both sides of the front seat.
Who can tell the size of an Aztec block and the width of the pleated panels? The insert is narrower at the top than at the bottom and I need to figure out that measurement.
Then I will need to know the proper measurements for the insert on the back of the front seat.
thank you
Jerry Whitfield
Winston salem NC
Greg P.
Posted 2017-08-31 12:20 PM (#547431 - in reply to #547394)
5001001002525
Ugh... I actually missed the part where he said he doesn't have any Aztec Fabric.
