Chrysler Imperial 1959-Transmission Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
RexiRexi |
Member Posts: 5 Location: Faroe Islands | Hi I have some problems with my A-488 Torqueflite transmission - when driving around for a couple of hours the transmission is not acting as it should - i.e. when I am activating the "N" push button (neutral) the car is going in reverse. The oil is changed and the oil temp is around 180-200F - any idea what is wrong?? (Chrysler Imperial 1959 kopi.jpg) Attachments ---------------- Chrysler Imperial 1959 kopi.jpg (82KB - 378 downloads) | ||
Expert 5K+ Posts: 9855 Location: Lower Mainland BC | I know nothing but it seems as if you push-button to transmission cable isn't adjusted quite right and when things warm up, that adjustment error results in the missed gear selection. Check the adjustment as per the factory manual. | ||
51coronet |
Extreme Veteran Posts: 360 | Nice car, is that the stock antenna? Back on the subject it does sound like the cable is out of adjustment or the pushbutton isn't engaging far enough possibly worn down on the inside. Hope you get it figured out | ||
60 Imp |
Location: North Australia | G'day Oliver, Nice looking Imperial. The colours really suit it. I had to search up Faroe Islands, never heard of them before, man, you are in a remote place, how did that car (and you) end up there??? Have you heard of the Online Imperial Club? Lots of info to help you out, I have added the transmission page link here just in-case you have not seen it. http://www.imperialclub.com/Repair/Transmission/index.htm Do you know any history of the car, specifically the transmission? What else have you done to solve the problem? You will find there are a couple expert transmission guys on this site, and I am sure they will chime in. Steve. | ||
RexiRexi |
Member Posts: 5 Location: Faroe Islands | Hi yes it is a stock antenna :-) , yes I am afraid I have to pull the transmission out for overhaul , it is a bit difficult to get parts etc. But the transmission is the last part of the car that is not overhauled I have during a 5 years period overhauled the entire car. (Imperial - innan.jpg) Attachments ---------------- Imperial - innan.jpg (87KB - 182 downloads) | ||
RexiRexi |
Member Posts: 5 Location: Faroe Islands | Hi Steve , the Faroe Islands Maybe the last paradise on Planet Earth :-), https://www.youtube.com/watch?v=ec5KwR41_iI I live her in the Faroe Islands , for apx 5 years ago I bought the Imperial from Sweeden - since then me and my son have been overhauled the car i.e new breaks all over-suspension - power steering-total engine overhaul and much more - only one item remaining and it is the transmission. Reg the transmission the valve block was removed and cleaned for apx 2yesrs ago - both bands adjusted acc to speck-we have also installed a external circulating pump and a filter for the transmission, installed to pipe connection in each side of the pan so the oil is circulating through the filter and the cooler this to keep the oil @ apx 180-200F and keep the oil clean, the old pipe connections are connected in to a loop (together) I have tested the transmission i.e. to give the care full throttle there is no problem for the transmission to handle that thare is on slip at all I am aware of the Imperialclub and have been using the side a lot very usefull Edited by RexiRexi 2017-08-28 6:05 PM | ||
