57 Chrysler Door Latch Adjustment
J97_Imperial
Posted 2017-08-11 8:35 PM (#546035)
Subject: 57 Chrysler Door Latch Adjustment
1002525
Hey all,
I'm having trouble adjusting my drivers side front door latch to allow the outside handle to open the door properly. No matter which way i move the slide connecting the outer handle to the latch, it doesn't go far enough up to allow the latch wheel to free spin. Anyone else having this problem or know how to remedy it?
Jacob
miquelonbrad
Posted 2017-08-18 9:26 AM (#546462 - in reply to #546035)
Subject: Re: 57 Chrysler Door Latch Adjustment
100050010010025
Hi Jacob,
You may need to replace your latch assembly. The tumblers inside are made of a poor pot metal, and they wear. Once you run out of adjustment, you are pretty much SOL. There was a thread on this a couple of years ago. I'll see if I can dig it up...
miquelonbrad
Posted 2017-08-18 9:59 AM (#546463 - in reply to #546035)
100050010010025
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=1710&p...
This is one thread, but I can't seem to find the one I wanted to...
Posted 2017-08-18 10:48 AM (#546468 - in reply to #546035)
50002000200050010025
Jacob, I run into this all the time because the different linkages and stuff wear out, and was at the end of it's adjustment when it was new etc. I just took the latch out of the door and cut the slot out longer to give it more adjustment. That's all it needed and it works well that way.
