Antenna Nut Removal
FINS!
Posted 2017-08-09 12:43 AM (#545883)
Subject: Antenna Nut Removal
50010010010010025
Anyone have a trick for removing the antenna nuts? This is on a '61 Imperial. There is nothing to grab on to the bezel, it is smooth but there are 2 little holes in the side. Last one I had to cut off to get the antenna out
Posted 2017-08-09 1:18 AM (#545886 - in reply to #545883)
Subject: RE: Antenna Nut Removal
5000200020005001001001002525
Maybe an Antenna Nut Removal Wrench (seriously)
http://www.ebay.com/itm/Antenna-Nut-Wrench-/261625967140
OR
Edited by 56D500boy 2017-08-09 1:25 AM
FINS!
Posted 2017-08-17 10:36 PM (#546447 - in reply to #545883)
50010010010010025
I got an antenna wrench (never knew they made those!). The pins are too large to fit in, I am working on modifying it but not sure it will work. I got one nut removed with 2 drill bits, and one person tapping one way with a hammer, and one the other. However that doesn't work for the more stuck ones. Any other ideas anyone?
oldhippie
Posted 2017-08-18 7:45 PM (#546508 - in reply to #545883)
Subject: Re: Antenna Nut Removal
I'd look for something like these below, with the right pin size...
http://www.flexarminc.com/blog/wp-content/uploads/2015/06/Spanner-W...
http://www.tractorshed.com/gallery/uptest/a82519.jpg
Edited by oldhippie 2017-08-18 7:47 PM
