Windshield wipers just quit working
Ray
Posted 2017-07-30 2:25 PM (#545171)
Subject: Windshield wipers just quit working
1000100100100100252525
Can someone help with troubleshooting this issue?
1961 Newport (Canadian Windsor)
Thanks
Posted 2017-07-30 2:59 PM (#545175 - in reply to #545171)
Subject: Re: Windshield wipers just quit working
500050002000100025
You need to give us some more info - just stopped in the middle of the action or? Not parking?
Ray
Posted 2017-07-30 4:10 PM (#545182 - in reply to #545175)
I attempted to use them yesterday and nothing happened, they were/are in the parked position.
Edited by Ray 2017-07-30 4:11 PM
Posted 2017-07-30 4:26 PM (#545188 - in reply to #545171)
500050002000100025
As for a first step, check that no wire has came unattached from the swith Ray.
There's no fuse for the windshield wiper motor but there's a Circuit breaker mounted on the back of the switch.
Ray
Posted 2017-07-31 7:40 PM (#545257 - in reply to #545188)
Wizard- Thanks for the tip. I will check it out tomorrow.
Posted 2017-07-31 7:53 PM (#545258 - in reply to #545171)
50001000100100100100252525
Check for power at the switch then on to the motor etc.
Plaza56
Posted 2017-08-18 11:47 AM (#546473 - in reply to #545171)
Did anything else stop working? Things are probably different in your car, but I have a problem with the ignition switch
in my 56 plymouth and when it acts up I lose the wipers, turn signals, gas and temp gauges, and the radio. Jiggling the
key in the switch brings everything back.
