1957 Chrysler Saratoga Gearshift control unit Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Judith |
Member Posts: 6 | Hello all. I am new to this board, but not the Saratoga! My Grandmother bought this car and it has been in the family ever since. She is beautiful, and I am trying to keep her running! We are having trouble with the Gearshift Control Unit. The Neutral button seems to collapse inside the gearshift box. I have seen it repaired, but this is happening more and more often. Does anyone have a similar experience with this? A recommendation/ solution? All input is greatly appreciated! | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | Is this a five button or four button control? Five buttons look like this: This last one is by Serge (sermey) in Switzerland | ||
Judith |
Member Posts: 6 | Mine is a five button, arranged like that last pic. When the button collapses into the housing, I have only fixed it by going in and re-aligning the clips. I will try to send a picture.... | ||
mstrug |
Expert 5K+ Posts: 6500 Location: Newark, Texas (Fort Worth) | If it is a 2 speed trans, you might want to get shifter that isn't worn out: Just a suggestion, I saw an NOS one a while back. http://www.ebay.com/itm/56-57-58-59-60-Dodge-Push-Button-Shifter-Co... http://www.ebay.com/itm/59-60-61-Dodge-Plymouth-DeSoto-Mopar-Powerf... Three speed: Rusty but you get the picture: Basic box is roughly the same for all of them 'cept the amount of button arms/levers. http://www.ebay.com/itm/1957-PLYMOUTH-PUSH-BUTTON-TRANSMISSION-CONT... Springs: http://www.ebay.com/itm/Mopar-NOS-Gearshift-Push-Button-Springs-P-F... Edited by mstrug 2017-07-29 6:57 PM | ||
Judith |
Member Posts: 6 | Here is a Picture: | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | Judith - 2017-07-29 6:52 PM Here is a Picture: Your photo didn't come through. We want to see it so you might want to read this: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=64340&... /Dave F. | ||
Judith |
Member Posts: 6 | try again (gearshift control box.jpg) Attachments ---------------- gearshift control box.jpg (23KB - 150 downloads) | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | Judith - 2017-07-29 9:36 PM try again Judith: You did get the upload to work. Just one problem you did the upload in the wrong thread. I've brought your photo from that thread over here to your thread: Not knowing that much, I would suspect that either the Neutral pushbutton rod has broken or the return spring has broken. Springs will be easier. Either way, it will have to be removed and investigated and fixed. Good luck. Edited by 56D500boy 2017-07-29 9:42 PM | ||
Judith |
Member Posts: 6 | Thanks for the input. We have repaired it on the fly when out and about, but I think someone that knows what they are doing will have to look deeper into it to do a real repair! We'll see how it goes. This is a great site. So glad I found it! | ||
DejaVu |
Member Posts: 31 Location: South Australia | Hi Judith, I don't have much to offer but I have had similar issues with my New Yorker push button pod. It isn't difficult to extract from the dash and I didn't find it that hard to pull down to replace a few springs - putting it back together spring-loaded was a bit more of a challenge but some patience is handy at that point! From memory there was a pin running through the latch that has a squashed end on it that I had to file down to enable extraction, which thereby released all the springy goodness within. I took plenty of photos to help me reassemble it. Getting the shift cable back on was fiddly. It works fairly well now. I'm no mechanic and it didn't present too much of a difficulty to have a go at but if you are uncomfortable, by all means seek help. For the record, mine had a busted tang that engages the start switch. Good Luck! | ||
Expert Posts: 3776 Location: NorCal | I suspect that the plastic push button has deteriorated where it connects to the steel "fork" in the mechanism allowing the button to be pushed in past the face plate. | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | 57chizler - 2017-07-30 3:27 PM I suspect that the plastic push button has deteriorated where it connects to the steel "fork" in the mechanism allowing the button to be pushed in past the face plate. Judith: I agree with 57chizler that the button rod might be broken. This is what they look like: Photo is from Serge (sermey) in Switzerland | ||
51coronet |
Extreme Veteran Posts: 360 | if is just worn down you can find replacements on ebay every now and then. You could also build the plastic back up with fiberglass resin or some other sort of 2 part epoxy. Main thing with this approach is making sure it sticks to the old plastic. | ||
Greg P. |
Elite Veteran Posts: 769 Location: Oley, PA | I have had a similar problem, but mine was due to the metal "fork" tines being bent apart so that the plastic pushes too far into it. Simple solution was to disassemble and re-bend the fork to the right shape. | ||
