Laugh at me: Lost one of the generator wiring nuts
Posted 2017-07-06 9:43 PM (#543674)
Subject: Laugh at me: Lost one of the generator wiring nuts
500020002000500100100100100
In order to remove and paint my 56 D500 valve covers, on the left side of the engine (the 1-3-5-7 bank), I had to remove (okay move) the generator/PS pump combo out of the way. In doing so, I had to disconnect the two wires on top of the generator. Somehow, I've managed to lose (drop somewhere), the nut for the bigger stud. Anybody know the size of the nut? Probably a machine screw thread, very fine threads. I didn't lose the smaller nut. 1 for 2.
On the upside, I found that there were two holes on the generator mounting bracket (which also came off and got painted) and when I re-installed the generator/PS this afternoon, I used the outer two holes which should help with air cleaner clearances.
Edited by 56D500boy 2017-07-07 8:37 AM
(55-58GeneratorDetailParts.jpg)
Attachments 55-58GeneratorDetailParts.jpg (92KB - 156 downloads)
Posted 2017-07-07 5:00 AM (#543685 - in reply to #543674)
Subject: Re: Laugh at me: Lost one of the generator wiring nuts
50001000500
I am thinking 1/4-28. If stud is 3/16" then 10-32. Some nuts are brass or copper.
Posted 2017-07-07 2:30 PM (#543705 - in reply to #543685)
20001000500100100252525
Yes, 1/4"-28
Posted 2017-07-07 7:24 PM (#543730 - in reply to #543705)
mstrug - 2017-07-07 5:00 AM
57chizler - 2017-07-07 2:30 PM
Yes, 1/4"-28
Went out to find 1/4"-28 not even sure if it was 1/4". Bought a 1/4"-20 (all they had - lumber yard - not a House of Bolts) knowing it was probably going to fail. (It did - but the 1/4" was correct)
While I was contemplating my next move, I started putting the fan belts back on. I needed a light to see the crank pulley and during that episode, I saw a nut laying on the cross-member below the front of the engine. 2 minutes later with my magnetic extendable parts retriever, I pulled it up and put on the generator. DING.
Thanks for your help though. Much appreciated.
Next time when I pull the nuts off the generator to move the wires, I will put the nuts back on the studs so they won't go "walkabout" on me.
Edited by 56D500boy 2017-07-07 7:26 PM
Posted 2017-07-09 3:58 PM (#543838 - in reply to #543730)
56D500boy - 2017-07-07 4:24 PM
Yes, 1/ I saw a nut laying on the cross-member below the front of the engine.
Oh boy, if I had a nickel for every time.........................
