1958 dodge custom royal - $1599 (osoyoos B C) Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forward Look Local Regions -> Canada Region | Message format |
mstrug |
Expert 5K+ Posts: 6500 Location: Newark, Texas (Fort Worth) | https://vancouver.craigslist.ca/van/cto/6119115751.html 1958 dodge custom royal .body mostly restored , doors painted, engine was done but dont turn.sitting too long. needs doner car, have lead on 2. no title. 1958 dodge custom royal VIN: 4924 LD21 cylinders: 8 cylinders drive: rwd fuel: gas paint color: black size: full-size title status: missing transmission: automatic | ||
Expert 5K+ Posts: 9902 Location: Lower Mainland BC | Obviously I am NOT the expert here (queue Chrycoman) BUT.... I think LD2L is a 1958 Coronet Custom V8 made in Los Angeles. REFERENCE: Pg 5/15 of http://www.jholst.net/55-58-parts-manual/information.pdf | ||
soiouz |
Expert Posts: 3480 Location: Montreal, Canada | For some reason, these two are still available too: http://www.kijiji.ca/v-classic-cars/winnipeg/two-1958-dodge-custom-... | ||
pennerdodge |
Regular Posts: 82 Location: Eastern Manitoba | Still available because i'm saving up to buy a boat lol. Otherwise i definitely would have been looking at them. | ||
Chrycoman |
Expert Posts: 1819 Location: Vancouver, BC | 56D500boy - 2017-06-19 9:28 PM Obviously I am NOT the expert here (queue Chrycoman) BUT.... I think LD2L is a 1958 Coronet Custom V8 made in Los Angeles. REFERENCE: Pg 5/15 of http://www.jholst.net/55-58-parts-manual/information.pdf Yes, "LD2L" decodes as "1958 (L) Dodge (D) V8 (2) Coronet (L)" That data plate was used only at the Los Angeles plant. Also note the "WCD-LA" just below and to the right of the "LD2L" - "West Coast Division - Los Angeles". Chrysler also listed the San Leandro plant (opened by Dodge Division in 1949) in 1955-58. even though the plant stopped building cars at the end of the 1954 model year. Suspect Chrysler had plans to reopen the plant once sales increased again. Never did though. The LA plant (Plymouth Division) was opened in June, 1932 to replace the Graham Brothers Truck plant in Stockton, CA, and closed at the end of the 1971 model year. | ||
Expert 5K+ Posts: 9902 Location: Lower Mainland BC | Chrycoman - 2017-07-01 6:07 PM Also note the "WCD-LA" just below and to the right of the "LD2L" - "West Coast Division - Los Angeles". Chrysler also listed the San Leandro plant (opened by Dodge Division in 1949) in 1955-58. even though the plant stopped building cars at the end of the 1954 model year. Suspect Chrysler had plans to reopen the plant once sales increased again. Never did though. The LA plant (Plymouth Division) was opened in June, 1932 to replace the Graham Brothers Truck plant in Stockton, CA, and closed at the end of the 1971 model year. Bill check your PMs for a question about the LA plants re: 56 Dodge. | ||
Expert 5K+ Posts: 9666 Location: So. Cal | LD2L could also be '58 Royal, correct? | ||
Chrycoman |
Expert Posts: 1819 Location: Vancouver, BC | Powerflite - 2017-07-02 1:56 AM LD2L could also be '58 Royal, correct? No, LD2-L would only be for a 1958 Coronet V8. The Royal has the same standard engine as the Coronet V8, which was the Dodge 325-cid V8, so it would also be LD2. But as the Royal is higher priced than the Coronet, the Royal would be LD2-M. For the model codes - "L" is for 1958 "D" is for Dodge The number is for the standard engine 0 "1" = 230-cid 6 "2" = 325-cid Dodge V8 "3" = 350-cid B block V8 The next letter is for the price class or series - L = Low = Coronet, Suburban, Sierra M = Medium = Royal H = High = Custom Royal and Custom Sierra Now, just to confuse things, although the Suburban and Sierra were in Dodge's Low price class, their base engine was the "3" engine, or 350-cid V8. Thus the Suburban and Sierra were LD3-L. There is also a variation for the Coronet - LD1-L and LD2-L. The cars with the Custom interior were LD1-L2 and LD2-L2 and the standard interior LD1-L1 and LD2-L1 Just to confuse things even more, serial numbers also started with LD1, LD2 and LD3, in 1958, but had no price class letter attached. Instead a letter was added for the assembly plant, if the assembly plant was not in Detroit. Thus "L" was added if the car was built in Los Angeles. No Coronet 6 models were built in LA, so you will only find LD2L- and LD3L- serial number prefixes. That hyphen becomes important - LD2-L is for a Coronet V8 (2 engine and Low price class) while LD2L - is for "2" engine (325-cid) and Los Angeles plant. The nicest thing to say about the 1958 assembly plant prefixes is that they were used only in 1958. | ||
Expert 5K+ Posts: 9666 Location: So. Cal | Now you have confused me. The data tag doesn't show LD2-L, it shows LD2L and is built in LA. So does this L in the model number indicate the price class or the LA plant? If it is the LA plant, then a Royal built in LA would have this same model number, right? Would a Detroit built car show LD2-L2 for the model or is this custom interior only shown on the build sheet or somewhere else? My LA built car has the custom interior, but the data plate only shows LD2L for the model. Chrycoman - 2017-07-02 4:58 AM ....That hyphen becomes important - LD2-L is for a Coronet V8 (2 engine and Low price class) while LD2L - is for "2" engine (325-cid) and Los Angeles plant. The nicest thing to say about the 1958 assembly plant prefixes is that they were used only in 1958. My '57 Chryslers also have the L prefix for the LA plant build in the VIN - they start as N57L and W57L with no dash. Whereas the Detroit '57 Windsor has W57-XXXX. So the assembly plant was also indicated in the '57 VIN. Their model numbers are completely different though, as C76 etc. | ||
Expert 5K+ Posts: 9902 Location: Lower Mainland BC | Powerflite - 2017-07-02 10:12 AM Now you have confused me. The data tag doesn't show LD2-L, it shows LD2L and is built in LA. So does this L in the model number indicate the price class or the LA plant? If it is the LA plant, then a Royal built in LA would have this same model number, right? Would a Detroit built car show LD2-L2 for the model or is this custom interior only shown on the build sheet or somewhere else? My LA built car has the custom interior, but the data plate only shows LD2L for the model.. I trust that the info below, i.e. pg 5/15 of the pdf that I quoted earlier will help to clarify the discussion: REFERENCE: Pg 5/15 of http://www.jholst.net/55-58-parts-manual/information.pdf Edited by 56D500boy 2017-07-02 12:25 PM (58DodgeModelDesignations.jpg) Attachments ---------------- 58DodgeModelDesignations.jpg (95KB - 539 downloads) | ||
