1959 DeSoto Turn Signal Switch / Brake Light Issue
Fireflite56
Posted 2017-06-13 9:25 PM (#542083)
Subject: 1959 DeSoto Turn Signal Switch / Brake Light Issue
10010010025
I have a 1959 DeSoto Fireflite that I am having issues with one of the brake lights on. The left side works every time - tail/brake/signal - just the way it should. The right side always works with the signal and taillight, but the brake light only works if the left signal is on OR I put a little pressure down one the signal switch (towards left signal postion). Before I tear into the column or spend money on a new signal switch, has anyone encountered something similar and is there an easy fix? I am very mechanically apt, but less so when it comes to electrical.
Thanks in advance!
Posted 2017-06-14 1:36 AM (#542092 - in reply to #542083)
Subject: Re: 1959 DeSoto Turn Signal Switch / Brake Light Issue
500050002000100025
I would, first of all check that the correct type of bulbs are installed and that they have proper contact and good ground.
Posted 2017-06-14 10:07 AM (#542116 - in reply to #542092)
5000200020005001002525
I would check the ground to the bulb. It could be that the turn signal is providing a different source of ground to make the brake light work. It is a long shot, but a lot easier to try. Most likely, though, it is probably a centering problem on your turn signal switch. You probably need to open it up and re-center it.
Fireflite56
Posted 2017-06-19 11:18 PM (#542490 - in reply to #542083)
10010010025
I believe I had checked bulb type at one time and tried different bulbs without success.
I took off the steering wheel this weekend and I noticed that there seems to be some white corrosion. A good cleaning, both at the socket and up at the signal switch, will probably be where I start. Powerflite, can you elaborate on the "centering" process? I have attached photos showing what it looks like.
Also, does anyone know exactly what the copper/brass tab (seen in the last photo) is for and where it goes? Mine was laying loose in the column when I pulled the wheel. Could this be a source of my problem?
(Switch 1.jpg)
(Switch 2.jpg)
(Switch Ground.JPG)
Attachments Switch 1.jpg (175KB - 187 downloads)
Attachments Switch 2.jpg (245KB - 198 downloads)
Attachments Switch Ground.JPG (24KB - 175 downloads)
