power steering rebuild Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Fellow Forward Lookers, Is there such a thing as power steering rebuild kit? My 57 New Yorker is leaking from Power steering area..Any help would be appreciated. Thanks, billy
billy |
Extreme Veteran Posts: 395 Location: upstate new york | C'mon guys...70 views and nobody can throw me a bone???? | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Sorry, there seems to be no kits, but RockAuto has some seals. If you demount the pump, with the old parts you'll surely find lip seals and bushing/bearings for it. | ||
Expert 5K+ Posts: 7395 Location: northern germany | billy - 2017-06-05 2:09 PM C'mon guys...70 views and nobody can throw me a bone???? you would have less than 70 if you would have revealed its for a 57 in the header. i understand the 57 system is completely different than 58&up. | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Thanks for your response Gentlemen...I will be more specific in the header in the future... billy | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | How about this one ? http://www.ebay.com/itm/Remanufactured-OEM-Genuine-Power-Steering-G... | ||
hemidenis |
Expert Posts: 3887 Location: Northen Virginia | The 57 PS pump is one of those over-engineered Chrysler devices, more likely to be found in a Turbine engine that in a road car. That particular PS pump is a nightmare to put together and you must have the proper tooling. Your PS is probably the aluminum version, (and one year only if I remember correctly) and you probably only need the seals, but I never saw a kit for it anywhere listed. I found a NOS kit at Carlisle last year, but i didn't even open it yet since my PS was working and i only painted it and change the seals. Remove that thing from the car is another difficult task, specially if the car is complete and running. | ||
Expert Posts: 3776 Location: NorCal | If leakage is the only problem you might try an additive like Lucas, it's worked for me on a couple of occasions. (Lucas PS.jpg) Attachments ---------------- Lucas PS.jpg (62KB - 202 downloads) | ||
1959Dodge |
Expert Posts: 2244 Location: Yorba Linda, Ca | As mentioned, the 58 is different, at least the later 58's. I'm talking about the power sterring box , not the pump. Strangely enough the earlier 58's used an aluminum steering box, whilst the later 58's used what they called "Constant control power steering" and that box (power steering unit) was made of cast iron. How do I know? Because I had to have the power steering box in my 58 New Yorker Convertible rebuilt due to bad leaks which were soooo bad that the lucas stop leap was no help at all. I used Firm Feel to rebuild the box. They are "Mopar Experts" as they used to race them. Firm Feel: Orders 1-800-FIRM-426 ( 347-6426 ) EMAIL | Technical Help 1-360-546-3633 EMAIL | Fax 1-360-574-6426 Firm Feel, Inc., 2730 NW Bliss Road, Vancouver, WA USA 98685 Gary Edited by 1959Dodge 2017-06-08 2:01 PM | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Thank you gentlemen for your replies...since it sounds like a nightmare in the making, i will go the Lucas route for now....when I can't deal with that any longer I'll try the rebuilder as mentioned here...thanks again guys... billy | ||
rebel |
Extreme Veteran Posts: 309 Location: Western Colorado | Billy, Is it the power steering pump on the engine that is leaking or is it the gear that is mounted down on the frame? I can probably give you the seal and bearing numbers if its for the aluminum bodied Thompson power steering pump. Bob | ||
hemidenis |
Expert Posts: 3887 Location: Northen Virginia | Sorry for the delay here they are the pictures of the PS. (IMG_0740b.jpg) (IMG_0852b.jpg) Attachments ---------------- IMG_0740b.jpg (137KB - 203 downloads) IMG_0852b.jpg (63KB - 186 downloads) | ||
tberd62 |
Veteran Posts: 206 Location: California | Nice job. So did you do this rebuild yourself? I have one i just pulled from my 57 D500 that needs a service. | ||
hemidenis |
Expert Posts: 3887 Location: Northen Virginia | No, the PS was working fine when removed so I only replace the exterior seals. 57 aluminum PS is something not to mess with it, there is not a kit to repair them as far as I know, all the kits start from 58 which is a complete different unit. | ||
