Help with 59 Plymouth Sport Fury Cowl Tag Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
RammJaeger |
Member Posts: 11 | Hi everyone, I'm new to the forum and was wondering if someone could help me with decoding my cowl tag for my 1950 Plymouth Sport Fury? The VIN is M29410311 and I'll attach an image of the tag. Thanks! (Photo May 26, 10 59 14 PM (2).jpg) Attachments ---------------- Photo May 26, 10 59 14 PM (2).jpg (209KB - 263 downloads) | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | SCHED = Scheduled date, first 2 are the build month and last 2 are the day = 0702 to be built on July 2nd (July 1959?) No. = 3271 (probably a sequence number) Model = MP2P "The 1959 models ushered in a new serial numbering system, the second in as many years. Adopted corporate-wide, the system used ten digits. The first digit was the code letter "M," signifying the 1959 model year. P = Plymouth The second numeral, using "1" for 6-cylinders and "2" for V-8s, indicated the type of engine (but did not designate which V-8 was installed). The third number in the sequence indicated model series, "3" signified Savoy, "5" Belvedere, "6" Fury, "7" station wagons (without designating series or differentiating between two- or four-door wagons). The fourth numeral indicated assembly plant, using "3" for Evansville, "4" for Los Angeles, "5" for Newark, "6" for Detroit, and "8" for Valley Park (St. Louis). The remaining six digits-all numerals-made up the sequential serial number, all beginning at 100,001." Reference: http://www.allpar.com/history/plymouth/1946-1959/cars-1959.html And MODEL = M, 1959 / P, Plymouth. After that is a 1 (6 cylinder) or 2 (8 cylinder) Then there is another letter, L = Savoy, M = Belvedere, H = Fury, P = Sport Fury Ref: http://59sportfury.net/59forum/viewtopic.php?t=1775 BT = Body type, all the different body types, models and engines has different numbers. 292 means Fury, V8, Sport 2 door hardtop. TR = Trim, interior. This code tells you what colour the bolster and seat were in all cars. Trim code = 347 = 347: Red PT = Paint = AA = Jet Black on Jet Black Another example: VIN breakdown: M295103368 M: 1959 2: Plymouth, V8 9: Sport Fury 5: Build in Newark 103368: 3368th build Sport Fury in Newark Date - 0416: build 16th of April 1959 Bdy (body) 292: Sport Fury hardtop Pnt (paint) XA1: Iceberg white top and Jet black body Trm (interior trim) 347: Red Option codes: 293: torqueflite 3 speed automatic 301: power steering 403: remote control mirror (deluxe) with matching passenger side mirror Reference: http://www.59plymouth.net/59forum/viewtopic.php?t=2792 Edited by 56D500boy 2017-05-29 9:34 PM | ||
RammJaeger |
Member Posts: 11 | Thank you very much for the information. It looks like the car has it's original colors then as the car is black on black with red interior. Thanks again! | ||
Matthew Keij |
Extreme Veteran Posts: 481 Location: The Netherlands | My 59 decoding popping up here and there, awesome! | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | Matthew Keij - 2017-06-01 9:21 AM My 59 decoding popping up here and there, awesome! Good job on that. I trust my "Reference" links were enough to show that I hadn't done the work, just brought the results back here for the original poster (I wasn't claiming credit for the work). Dave F. | ||
Matthew Keij |
Extreme Veteran Posts: 481 Location: The Netherlands | Thanks! No problem on the post, link or anything. I'm just happy my post can help other forward lookers! It wasn't sarcasm or something. I just think it's awesome. We are all here to help each other and that's why I posted all that stuff on the 59 P forum | ||
