Spring Special 58 DeSoto Firedome Sportsman
Jump to page : 1 2 3 4 5 6
Now viewing page 5 [50 messages per page]
58DeSoDodge59
Posted 2018-11-26 11:28 PM (#574187 - in reply to #574186)
Subject: Re: Spring Special 58 DeSoto Firedome Sportsman
(desotonspring.jpg)
Attachments desotonspring.jpg (119KB - 413 downloads)
58DeSoDodge59
Posted 2018-11-27 12:37 AM (#574190 - in reply to #574187)
DeSoto in the Winter.
(christmas1958.jpg)
Attachments christmas1958.jpg (195KB - 413 downloads)
58DeSoDodge59
Posted 2018-11-27 7:52 PM (#574242 - in reply to #574190)
Since the frame is bad and needs repaired, I hung the body from the ceiling, so I can work on the frame easier.
(hangtime.JPG)
Attachments hangtime.JPG (242KB - 468 downloads)
58DeSoDodge59
Posted 2018-12-02 9:56 PM (#574540 - in reply to #574242)
I almost found a part number on the leaf spring. Anyway, since it got up to 60 degrees today, I pushed the
frame outside so I could clean it up. I sprayed in each one of the holes. I got a lot of dirt, rocks and one rats
nest out of it.
(almost.JPG)
(beginin.JPG)
(chassis.JPG)
(delta.JPG)
(eggy.JPG)
Attachments almost.JPG (240KB - 405 downloads)
Attachments beginin.JPG (239KB - 438 downloads)
Attachments chassis.JPG (247KB - 458 downloads)
Attachments delta.JPG (228KB - 432 downloads)
Attachments eggy.JPG (240KB - 480 downloads)
58DeSoDodge59
Posted 2018-12-03 2:59 PM (#574573 - in reply to #574540)
As I was cleaning out the frame, I jacked up the front of it so the rats nest would go out the big hole.
(framedrain.JPG)
Attachments framedrain.JPG (234KB - 411 downloads)
58DeSoDodge59
Posted 2018-12-23 6:46 PM (#575710 - in reply to #574573)
Well Heck. I cut a section from a 59 Dodge frame, only to find out that it is a 1/2 inch smaller all
the way around. So I am going to need a section from a big Chrysler or DeSoto.
Nathan, Do you still have that frame?
Edited by 58DeSoDodge59 2018-12-23 6:49 PM
(framesec.JPG)
(framesect.JPG)
Attachments framesec.JPG (281KB - 388 downloads)
Attachments framesect.JPG (218KB - 423 downloads)
Posted 2018-12-23 8:52 PM (#575715 - in reply to #539736)
5000200020005001002525
I do still have it, but I cut it up with a plasma cutter to fit into a truck bed, and I cut it right at the downturn where your largest rust spot is. Sorry, I didn't know you were going to want it.
However, I don't recommend that you weld in a whole new section like that anyway. You should just patch it in smaller pieces. Welds are never as strong as the original metal, and you should remove as little of the original frame as possible. So I recommend that you use the Dodge section you have and cut it up to patch up the rusted part. But don't cut out an entire frame section because it won't be as strong that way and you will risk it breaking apart in the future. If you insist on doing an entire section, you will need to weld braces over the sides of the welds to make them stronger. But if you just patch in the rusted parts, cutting away only the parts that are bad, you should be able to keep it looking stock without worrying about it's structural integrity. Just make sure the welds penetrate well and are set hotter than usual to ensure that.
58DeSoDodge59
Posted 2018-12-23 11:12 PM (#575719 - in reply to #575715)
No problem. Thanks anyway.
Yes. I was just going to cut away the rusty sections, like the bottom. And half way up the sides in some areas.
Removing only what is necessary. The problem is that the DeSoto frame is 5 inches across the bottom, but the
Dodge frame is only 4 1/2 inches. So, I would rather get a frame that is the correct size, so I don't have to
modify it to fit.
Does anybody have a big 1958 Chrysler or DeSoto frame section that they can send me?
Posted 2018-12-23 11:53 PM (#575722 - in reply to #539736)
5000
I would just weld the lower section.
if you weld it right it will be stronger
Get a nice angled edge on both pieces and give it some room, turn the welder up and let er rip
I spend 3 hours shoving a pressure sprayer hose up my old frame, finally got it spotless. Sprayed cavity wax inside the frame.
I guess a big chrysler is different than a dodge, smaller wheelbase calls for smaller frame.
58DeSoDodge59
Posted 2018-12-24 11:06 PM (#575772 - in reply to #575722)
What the heck is cavity wax?
Posted 2018-12-25 12:55 AM (#575779 - in reply to #539736)
5000
search broke?
Just an example.
https://www.kbs-coatings.com/Cavity-Wax.html
58DeSoDodge59
Posted 2018-12-25 11:13 AM (#575793 - in reply to #575779)
Sorry. I did not do a search. I did not know that was a real thing. I thought you were just making stuff up.
Cavity wax sounds something like a new KY jelly.
58coupe
Posted 2018-12-25 1:12 PM (#575797 - in reply to #539736)
100050010010025
I believe that LPS3 will do the same job and is cheaper. we used it a lot in aircraft to prevent corrosion.
Posted 2018-12-25 3:05 PM (#575800 - in reply to #539736)
5000
Actually there are 100's of vendors. I just linked a quick search.
I went with 1 gallon of "undercoating in a can". Its black and goes on pretty thick and doesnt run so much.
https://www.amazon.com/TP-Tools-Undercoating-Flexible-TP-3043/dp/B07...
I have used like 10 different ones. Eastwood is overpriced also, fluidfilm is too runny.
Get a cheak undercoating sprayer with a wand off amazon, 59$ for a gallon.
https://petroleumservicecompany.com/undercoating-in-a-can/
Posted 2018-12-25 10:33 PM (#575815 - in reply to #539736)
My current frame section goes from the large rust area forward, and backward. If that can help you, I will send it to you if you pay the shipping. I can cut it as small as you like to save shipping cost. But my current cut does go through that major rust area. But if you weld the two parts together on both sides before you use them to patch, it would be strong that way. Just an option if you can't find another frame to cut.
58DeSoDodge59
Posted 2018-12-27 10:21 PM (#575903 - in reply to #575815)
Thanks Nathan, but I think that Wayne in Ohio is going to help me. I appreciate your help.
58DeSoDodge59
Posted 2019-03-09 10:50 AM (#579074 - in reply to #575903)
Okay, it is time to get back to work on this. And I am following all you guys that have a 58 DeSoto in the works.
I hope everyone gets a lot done on their cars this year. Maybe we can have a 58 reunion in 2020.
When I got this car, I knew that I would be needing new door panels, so I ordered them back in Oct. 2017.
I finally got them this passed week. It will still be a long time before I get to the interior. I am working on the frame now.
(frontside.JPG)
(holesbackside.JPG)
(passdoorbefore.JPG)
(newbushings.JPG)
Attachments frontside.JPG (187KB - 385 downloads)
Attachments holesbackside.JPG (135KB - 368 downloads)
Attachments passdoorbefore.JPG (239KB - 355 downloads)
Attachments newbushings.JPG (243KB - 366 downloads)
58DeSoDodge59
Posted 2019-03-26 8:53 PM (#579956 - in reply to #579074)
I took the grill/screen off of the front bumper. I found two different styles of clips that were holding it on.
Which one is correct? Maybe both?
(grillclips.JPG)
(grillclips2.JPG)
Attachments grillclips.JPG (226KB - 362 downloads)
Attachments grillclips2.JPG (241KB - 363 downloads)
Posted 2019-03-27 10:22 AM (#579970 - in reply to #539736)
The flat ones are the only ones familiar to me.
Posted 2019-03-27 11:40 AM (#579976 - in reply to #539736)
I agree. Both of my '58 DeSoto grilles are held on with the flat metal versions. I don't have any of the spring clip types.
58DeSoDodge59
Posted 2019-03-29 12:25 AM (#580055 - in reply to #579976)
That wire/spring type clip is so perfectly made, if it is not original to the 58 model, maybe it is from
an earlier or later model. ?
Also, does anyone else have the rubber protection strips on the bottom of their grille, like this one?
(grille.JPG)
Attachments grille.JPG (144KB - 344 downloads)
Posted 2019-03-29 10:53 PM (#580105 - in reply to #580055)
5000500050005000200050025
Not sure why you didn't just re-use those original door panels .....
Nice to see someone else understand and work with SMS, rather than just bellyache
about them. They do awesome work. You just gotta put that wheel in motion when the
car is in teardown, so they'll be ready way before you need them.
58DeSoDodge59
Posted 2019-04-02 2:17 PM (#580299 - in reply to #580105)
Doctor DeSoto - 2019-03-29 10:53 PM
The only thing that I would like to bellyache about is the way they lie to you in their emails.
Don't tell me that they are in the final stage, and should be ready next month when you know it is
going to be another 10 months before they are done. Just tell me it will be 10 months. I'm a
big boy, I can take it. They got me all excited after 6 months telling me that they were in the final stage.
I'm sure they got of my emails.
Posted 2019-04-03 1:11 AM (#580322 - in reply to #539736)
5000
does the squeaky wheel get the grease?
If you hadn't emailed it might have been another two years? I know this stuff is all hand labor and a total pita...
I swear im going to start making door panels... need the electro welder though and it probably give you cancer
I will probably just make mine like this
https://www.youtube.com/watch?v=PYMZCg-uuOc
Edited by mikes2nd 2019-04-03 1:18 AM
58DeSoDodge59
Posted 2019-09-08 8:48 PM (#587277 - in reply to #580322)
I cut out the rusty part of the frame.
I got the rest of the rats nest out of it.
Then I fitted a good piece of frame, (from a 57 Chrysler), to it.
(ratsnframe.JPG)
(fitting.JPG)
Attachments ratsnframe.JPG (212KB - 320 downloads)
Attachments fitting.JPG (233KB - 308 downloads)
58DeSoDodge59
Posted 2019-09-08 9:01 PM (#587278 - in reply to #587277)
Also, (with a little help), I found the engine number that is stamped on the frame.
(engonframe.JPG)
Attachments engonframe.JPG (212KB - 307 downloads)
Posted 2019-09-08 11:22 PM (#587281 - in reply to #539736)
Perfect. That's how I would have done it too. Just use a lot of power to ensure you get good penetration. If you are concerned with strength in certain areas, you can plug weld another plate across the weld on the inside of the frame so it won't be visible when done.
58DeSoDodge59
Posted 2019-10-26 6:40 PM (#589327 - in reply to #587278)
This sign was displayed, starting, Dec. 15th 1957, in the Mobile gas stations.
(IMG_0861 (2).JPG)
Attachments IMG_0861 (2).JPG (185KB - 297 downloads)
58DeSoDodge59
Posted 2019-10-27 7:16 PM (#589377 - in reply to #587278)
This is why I have to replace the rear springs.
(numbers2.JPG)
(numbers3.JPG)
Attachments numbers2.JPG (237KB - 305 downloads)
Attachments numbers3.JPG (235KB - 290 downloads)
58DeSoDodge59
Posted 2019-10-27 7:28 PM (#589378 - in reply to #589377)
We already know that the painters put their mark on this car. Now, the welders,
on the assembly line had some fun with it.
(numbers4.JPG)
(numbers6.JPG)
Attachments numbers4.JPG (249KB - 285 downloads)
Attachments numbers6.JPG (244KB - 291 downloads)
58DeSoDodge59
Posted 2019-10-27 7:46 PM (#589381 - in reply to #589378)
I found some more numbers. 659 on the bracket.
And I found a painted on number, on the frame where I did the repair. I did not even see
it until I did some sanding and washed the frame. It says -1820338 ..... -57A .
Edited by 58DeSoDodge59 2019-10-27 7:56 PM
(numbers5.JPG)
(numbers7.JPG)
(numbers8.JPG)
Attachments numbers5.JPG (212KB - 346 downloads)
Attachments numbers7.JPG (241KB - 291 downloads)
Attachments numbers8.JPG (300KB - 300 downloads)
Posted 2019-10-27 11:38 PM (#589390 - in reply to #539736)
See if you can make out the letter in front of the number. Mine says "B" there. Also, the letter after the 57 date is "B". Maybe your's says "A" in both places or maybe it is a "B" and an "A". Your number is a little different from mine as well. Check and see if it might be the same or not. I suspect that they are really the same number.
Edited by Powerflite 2019-10-27 11:42 PM
(DesotoFrameNo.jpg)
Attachments DesotoFrameNo.jpg (370KB - 290 downloads)
Posted 2019-10-27 11:46 PM (#589393 - in reply to #539736)
5000
look 8 inches on top in front of the passenger torsion bar. the vin should be there.
58DeSoDodge59
Posted 2019-10-28 7:27 PM (#589435 - in reply to #589390)
I do believe it is a "B" in the front of the number. All you can really see is the lower curved section of the B.
And I missed the number by one digit. It reads B-1820308 .
For the date, I can see the top part of a straight line . So all I can read is 1 - 57 A .
Here is a different angle. Maybe you can see the ghost outline of the "B".
(numbers9.JPG)
Attachments numbers9.JPG (196KB - 291 downloads)
58DeSoDodge59
Posted 2019-10-28 7:41 PM (#589438 - in reply to #589393)
mikes2nd - 2019-10-27 11:46 PM
The only thing in that location is the engine number.
It reads LS35508 .
(numbers10.JPG)
Attachments numbers10.JPG (242KB - 300 downloads)
Posted 2019-10-28 8:27 PM (#589442 - in reply to #539736)
Yeah, I see the B on there. I wonder what they stand for. The one next to the date probably denotes an early or late shift, but I'm not sure what the B in front of the part number stands for.
ToMopar
Posted 2019-10-29 1:22 PM (#589478 - in reply to #539736)
10001002525
off topic
@ Nathan - on the picture above I can clearly see your new leaf spring
BTW my frame shows B-1675805 3-20-57A
Posted 2019-10-29 2:41 PM (#589480 - in reply to #539736)
Thanks for the info Tom. A different part number for a wagon frame, as well as from a '57 model makes sense, but the mysterious "B" persists.
Yeah, those are the new springs I had made at the truck shop.
normsclassicradio
Posted 2019-10-30 2:46 PM (#589527 - in reply to #539736)
100100252525
Is it B for Budd? Didn't they build frames for Chrysler back in the day?
Posted 2019-10-30 4:27 PM (#589529 - in reply to #539736)
5000
if the engine number is on the frame, you could find the vin right?
Posted 2019-10-30 5:53 PM (#589536 - in reply to #539736)
50001000100100100100252525
Great car! Here is some info on paint, if you already have it, you can delete it: http://paintref.com/cgi-bin/colorcodedisplay.cgi?type=paint&paint=5...
http://paintref.com/cgi-bin/chipdisplay.cgi?year=1958&manuf=DeSoto&...
58DeSoDodge59
Posted 2019-10-30 7:02 PM (#589538 - in reply to #589529)
mikes2nd - 2019-10-30 4:27 PM
I don't think anyone has found the VIN on the frame of a 58 DeSoto. ?? If anyone has, I would like to see it.
22mafeja
Posted 2019-10-31 8:04 AM (#589553 - in reply to #589538)
50010025
I have two vin numbers on my firedome 58 frame- but I have punched them myself since in Finland we have to get that done prior to registration. One number is required but I
punched two just for fun!
Edited by 22mafeja 2019-10-31 8:06 AM
moparsteve
Posted 2019-10-31 11:29 AM (#589554 - in reply to #539736)
Subject: RE: Spring Special 58 DeSoto Firedome Sportsman
10001002525
pretty rough.... not many spring specials left hardly any parts cars to pick clean..john in calif..
drop dead goregous when done.. one on ebay not too long ago..
58DeSoDodge59
Posted 2019-11-05 8:36 PM (#589783 - in reply to #587277)
The other side. Welded.
(newsection.JPG)
Attachments newsection.JPG (243KB - 309 downloads)
Posted 2019-11-07 11:06 AM (#589851 - in reply to #539736)
5000
turned out great,
58DeSoDodge59
Posted 2019-11-30 10:33 PM (#590950 - in reply to #589783)
I painted the frame with POR15, and Tiecoat Primer. Ready for the final color.
(IMG_0921 (2).JPG)
Attachments IMG_0921 (2).JPG (197KB - 293 downloads)
58DeSoDodge59
Posted 2019-12-04 8:34 PM (#591086 - in reply to #590950)
Painted Chassis coat black.
(framepaint.JPG)
Attachments framepaint.JPG (244KB - 268 downloads)
58DeSoDodge59
Posted 2019-12-25 4:56 PM (#592013 - in reply to #591086)
Something different
(differential.JPG)
Attachments differential.JPG (245KB - 260 downloads)
22mafeja
Posted 2020-03-05 2:50 AM (#595241 - in reply to #589851)
50010025
Keep up the strong work! One day it is ready...
Thanks for sharing that mousesaurus nest in the glove box...it gets me to remember my own finds...mostly in the rear seat or on top of the headliner.
That picture explains always what this is about and why we do this - we are crazy people...
