Wanted 392 Air Cleaner Brackets Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
FINS! |
Elite Veteran Posts: 943 | Wanted the brackets that hold the air cleaner to the valve cover on 392s. | ||
matador440 |
Elite Veteran Posts: 690 Location: BELTSVILLE, MARYLAND 20705 | i have them if i can find them | ||
FINS! |
Elite Veteran Posts: 943 | Thanks, if you find them let me know | ||
ToMopar |
Elite Veteran Posts: 1157 Location: D-70199 Heslach | parasitical I am use this thread, because I miss the same bracket on my 57' 341 | ||
rebel |
Extreme Veteran Posts: 309 Location: Western Colorado | FINS, If all else fails, they shouldn't be too difficult to make. The rear bracket is 1" wide x 1/16" thick and the front is 7/8" wide x 1/16 thick. I have my carb off at the moment and could take some pictures and make a drawing, if that would help. You don't have a 2806s carb laying around for a 392??? Bob | ||
FINS! |
Elite Veteran Posts: 943 | Thanks, if you could get some photos of the brackets that would be great. No extras of those carbs, sorry. | ||
rebel |
Extreme Veteran Posts: 309 Location: Western Colorado | Here are some pictures. Hope this helps. Bob Edited by rebel 2017-05-16 8:58 AM (1958 392 hemi air filter brackets 001.JPG) (1958 392 hemi air filter brackets 002.JPG) (1958 392 hemi air filter brackets 003.JPG) (1958 392 hemi air filter brackets 004.JPG) (1958 392 hemi air filter brackets 005.JPG) (1958 392 hemi air filter brackets 006.JPG) Attachments ---------------- 1958 392 hemi air filter brackets 001.JPG (92KB - 123 downloads) 1958 392 hemi air filter brackets 002.JPG (93KB - 127 downloads) 1958 392 hemi air filter brackets 003.JPG (76KB - 129 downloads) 1958 392 hemi air filter brackets 004.JPG (72KB - 124 downloads) 1958 392 hemi air filter brackets 005.JPG (115KB - 122 downloads) 1958 392 hemi air filter brackets 006.JPG (121KB - 114 downloads) | ||
FINS! |
Elite Veteran Posts: 943 | Thanks. Now I know what I'm looking for.... I need to get my motor looking as beautiful as yours, wow. What paint did you use on it? | ||
hemidenis |
Expert Posts: 3887 Location: Northen Virginia | I need the same brackets! | ||
rebel |
Extreme Veteran Posts: 309 Location: Western Colorado | Thanks! The silver and black are both Bill Hirsh high temp engine paint. Seems to be quality paint and the closest match to stock colors that I could find. The exhaust manifolds are VHT ultra high temp that's no longer available. Bob | ||
FINS! |
Elite Veteran Posts: 943 | Thanks. Did the Bill Hirsh paint take as long to dry as he says it does (a week to cure). And did you use a brush or a spray? It really looks nice. | ||
rebel |
Extreme Veteran Posts: 309 Location: Western Colorado | I sprayed it. It will dry enough to handle in a couple of hours. I don't doubt that full cure would take a week or more. Lots of paint takes several days for full cure. Today I used black VHT engine enamel on two exhaust supports for an old Harley, and it says 7 days to full cure. With most of the engine enamels I use, I will wait a day and then heat the painted part to 200 degrees for 1 hour. If I really want the best durability I will wait until the part is cool and then reheat it to 400 degrees for 1 hour. That has always seemed to work fine for me. Some of my old Harley cylinders that I have painted, and cured, look great after 20 years. Thanks for the compliments! Bob | ||
FINS! |
Elite Veteran Posts: 943 | Ok, that's good. I thought "set up" time might be really long. I wish I had the facilities for baking paint as I know how much that improves durability. That's a show quality engine you have there. | ||
rebel |
Extreme Veteran Posts: 309 Location: Western Colorado | Garrett, If you have the room, and the electricity, for an electric stove, you might go to an appliance store. They will usually haul off a customers old stove and will sell it for very cheap. A friend of mine actually was paid $10.00 just to haul one off. That was 15 years ago and he is still using the oven. Burner's didn't work, but all he needed was the oven. Just a thought. Bob | ||
rebel |
Extreme Veteran Posts: 309 Location: Western Colorado | Has anyone found any of the Hemi air filter support brackets?? Bob | ||
Expert 5K+ Posts: 9651 Location: So. Cal | I have collected a lot of Chrysler hemi parts since 1981, and I have never been able to lay my hands on those. Those things just get tossed long before a real Chrysler guy gets ahold of the motor. Might be best to get detailed dimensions and make your own. Poly motor brackets are no problem since hot rodders aren't actively trying to dislodge them. | ||
rebel |
Extreme Veteran Posts: 309 Location: Western Colorado | I would be willing to re-create a couple of sets of these brackets, if someone is interested. The material cost is hardly anything, but the labor would be at least 2-3 hours. Let me know if anyone is interested. Bob | ||
Expert 5K+ Posts: 9651 Location: So. Cal | If you end up doing a batch of them, I would be interested in a set - depending on cost. | ||
rebel |
Extreme Veteran Posts: 309 Location: Western Colorado | When I get a little time, I'll pick up some steel and make a set. Lets see how they come out. The front one should be fairly easy but the rear has a couple of hard bends. I'll take mine off the car to use as a pattern. I need to re-blast them and repaint anyway. Should have used black epoxy primer instead of gray. Bob | ||
mstrug |
Expert 5K+ Posts: 6498 Location: Newark, Texas (Fort Worth) | http://www.ebay.com/itm/1957-Chrysler-Desoto-Dodge-Imperial-V8-Air-... 2361288803?hash=item3619cfe463:g:yJgAAOSwKytZNa7C&vxp=mtr | ||
rebel |
Extreme Veteran Posts: 309 Location: Western Colorado | For sure not 392 hemi. Don't know how the air filter mounted on a 57 Dodge Cornet, but thats probably what it's for since it was in the trunk of that model car. These are the brackets off my 58 N/Y'er, 392. Edited by rebel 2017-06-07 9:56 AM (392 hemi air filter housing mounting brackets 001.JPG) (392 hemi air filter housing mounting brackets 002.JPG) Attachments ---------------- 392 hemi air filter housing mounting brackets 001.JPG (118KB - 127 downloads) 392 hemi air filter housing mounting brackets 002.JPG (98KB - 126 downloads) | ||
hemidenis |
Expert Posts: 3887 Location: Northen Virginia | Bob, if you can make me a set I will be glad to buy them. | ||
rebel |
Extreme Veteran Posts: 309 Location: Western Colorado | Denis, I'll send you a PM. Bob | ||
hemidenis |
Expert Posts: 3887 Location: Northen Virginia | I just would like to everybody know that Bob sent me a set of brackets and they look fantastic, I can't wait to put them on my car. More than recommended..Thanks BOB! | ||
Expert 5K+ Posts: 9651 Location: So. Cal | I agree. Very well made. I received a set as well. Thanks Bob! | ||
rebel |
Extreme Veteran Posts: 309 Location: Western Colorado | Thanks Guys! I'm glad they will work out for you! Let me know if I can help out with anything else. Bob | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Bob, PM sent....hoping you still have brackets... Thanks, billy | ||
