57 Royal with 392 project Jump to page : < ... 2 3 4 5 6 7 8 9 10 11 > Now viewing page 8 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 5006 | ran out of welding gas so i couldn't finish the darn driveshaft...... have to go find a solid rubber mat to make the gas tank drop a bit... I honestly could do an in tank pump... the problem is fitting it in the tank, as the top of the tank is covered. This pump should be fine for volume I think. I do have a big pcv valve, no downdraft. I was thinking about putting an access port under the back seat to get to the gas pump heh. I will be painting any shiny bolts. | ||
Expert 5K+ Posts: 5006 | this is taking way to darn long... https://www.youtube.com/watch?v=6tRj3kvaIkM | ||
Expert 5K+ Posts: 9663 Location: So. Cal | What master cylinder did you end up with? The reservoir fittings are really tall on it, but I like it otherwise. | ||
Expert 5K+ Posts: 5006 | its the 79-80 dodge Truck master its 1.125 bore https://www.rockauto.com/en/moreinfo.php?pk=309581&jsn=3 https://www.cardone.com/product/10-1860-master-cylinder | ||
Expert 5K+ Posts: 5006 | reservoir fittings are not seated inside yet | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | That is my MC of choice, all three of my Plymouths have it. | ||
Expert 5K+ Posts: 5006 | Cool glad im in good company... Its pretty massive. Do you use a proportioning valve or just let er rip??? Your using disc/drums? Starting to look almost like a running engine... The little s**t is killing me... Ordered a gas pedal boot... and I don't have a good steering column cover... Farking annoying when im missing bolts or certain little parts... Had to order some linkage parts... uhg wait... I don't know i need them but hey... I ordered turquoise vinyl paint also... have to wait. Ill get the carb in, and start the heater core and box finally. Fully cleaned out and getting set for wiring the whole car. Im going with 58 tail lights, the regal lancer front pieces also(the big brows) and Dual 58 head lights. I tested my horns. I have two types(autolite and spartan(I went with the spartans, they work like new))... would someone explain why are there so MANY goddarn different horns on these cars? Theres like 50 parts nums Edited by mikes2nd 2020-08-14 11:02 PM (HemiCarb.jpg) Attachments ---------------- HemiCarb.jpg (237KB - 380 downloads) | ||
Expert 5K+ Posts: 5006 | getting wiring ready... ez wire harness 20 circuit kit gm headlight switch led headlights(looking for similar to challenger yellow daytime running lights), turn signal is yellow inset lens... giving shoutout to new challenger.. GM electronic ignition Electronic choke Voltmeter(replacing) Back up lights on rear license plate surround 4 stop lights(58 housings) Clock led dash lights? under dash lights Concerned about column mapping... Original oil gauge 260 amp alternator dual electric fans mini high power starter variable wiper motor 58 dual headlights with 57 dodge bumper (2018-Dodge-Challenger-SRT-Hellcat-Widebody-Front-Detail.jpg) Attachments ---------------- 2018-Dodge-Challenger-SRT-Hellcat-Widebody-Front-Detail.jpg (316KB - 370 downloads) | ||
Expert 5K+ Posts: 5006 | https://youtu.be/7TX_Spx7xQI | ||
60 Imp |
Location: North Australia | She's coming together Mike! looks awesome. This is going to be a neat car, I hope you change your stance, and drive the wheels off this thing. Steve. | ||
Expert 5K+ Posts: 5006 | Brakes are complete and bled... just may need some fine tuning on the adjustable pedal rod, this thing will stop on a dime i bet, pedal feels great... going to summit today to get a tranny cooler. finishing up hoses, hopefully putting the heater core and box in today... then clean the whole inside out for wiring starting thurs... finally... I will start buffing some trim also... https://youtu.be/W2oVo8OWijI https://youtu.be/ZyRctJ-RSb8 https://youtu.be/F0oKpOgUEmI | ||
Expert 5K+ Posts: 5006 | s**tty paint on the trunk edges... barely touched it... replaced the trunk hinge.... https://www.youtube.com/watch?v=ZPdnHlIragU | ||
Expert 5K+ Posts: 5006 | https://www.youtube.com/watch?v=k-tNRiTeaZg Shifter cable is adjusted, gas pedal in, kick down adjusted trying to get the trans cooler in. tons of crap done. Running some wiring now.. | ||
Expert 5K+ Posts: 5006 | going with Ron Francis ignition switch also.. have to map it into the bezel somehow... https://www.ronfrancis.com/prodinfo.asp?number=IS%2D02 (IS-02-Md.jpg) Attachments ---------------- IS-02-Md.jpg (92KB - 371 downloads) | ||
Expert 5K+ Posts: 9663 Location: So. Cal | Then you will have to have 2 keys for the switch and doors. Why not use a '56 switch or a '57 Plymouth or DeSoto switch instead? | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | What is the advantage of that ignition switch? The factory one fits in the bezel. | ||
Expert 5K+ Posts: 5006 | I have the 57 dodge switch, I guess I could use it, just ignore the other wires... i wanted to simplify it, but as long as i only use the circuits i need im good. ill have to check it. I may have been thinking the headlight switch is the "fuse box" switch | ||
Expert 5K+ Posts: 5006 | https://www.youtube.com/watch?v=_pVdsmWo3Bc all this custom little s**t is crazy... getting close to wiring... | ||
Chrispy |
Extreme Veteran Posts: 520 Location: Colorado Springs, Colorado | So how much hood clearance would you say you have with the HH intake and that AVS? i've been told the HH intake is too tall for these cars but i've never been told by how much. I have one i want to use in my firesweep because the stock intake is terrible. | ||
Expert 5K+ Posts: 5006 | I have about an inch, it fit... I went to a spector low profile intake. I might adjust it a bit and paint it black. I am thinking about cutting the tubes on each side back also.... not using the tubes of course. https://www.youtube.com/watch?v=NB1_ZnBG4eI https://www.youtube.com/watch?v=nATSHjWCCTY (618YnfVhilL._AC_SL1500_.jpg) Attachments ---------------- 618YnfVhilL._AC_SL1500_.jpg (38KB - 355 downloads) | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | The headliner dye turned out really nice. Hope you can use it! It is normal for paint materials to build up on edges of panels. It's a consequence of the material flowing out, and it is just something you have to watch out for. It's one of the reasons that high-end paint jobs get sanded between each coat, to flatten that area so you don't get a "bump" around panel edges after laying down several layers of primer/paint. To preface this, I am just saying this as an observation watching your car come together contrasted with my own experience of building the Chrysler. It is interesting to see your use of aftermarket parts in your build, and the challenges they can sometimes cause. Obviously I did some custom / one-off stuff on my car, but believe it or not, I did try to refinish and reuse all the OEM parts and fasteners wherever possible. Partially because I wanted it "period correct-ish" but also because they were already there, so they were free! This comment was prompted by the aftermarket radiator, necessitating the aftermarket trans cooler, and the myriad small bits and pieces needed to get the systems working properly. I did have the same thought while you showed the brake light switch too, lol. You have done a good job of planning ahead and making sure all that is accounted for, so good on ya. The car is coming along very nicely, and just wanted you to know, someone does watch your vids. | ||
Chrispy |
Extreme Veteran Posts: 520 Location: Colorado Springs, Colorado | 1” eh? That’s... tight for engine movement... I thought about getting the carb pad milled down some, it will hurt intake performance some but it won’t be as bad as hitting, I don’t want to cut the hood. Edited by Chrispy 2020-09-13 8:41 PM | ||
Expert 5K+ Posts: 5006 | oh im not doing a hood scoop no way... Its actually the front edge that comes closest... so it would have to rock a ton...I just put the wiring harness in today... holy cr@p im spending half the time looking sh*t up... | ||
Expert 5K+ Posts: 5006 | just about done wiring.. moving inside to the dash now... repainted the trunk... Going to prime the engine again, and get hopefully test crank it over soon.. https://www.youtube.com/watch?v=rDlKyZKw7pE | ||
Expert 5K+ Posts: 5006 | I actually turned the engine over with the starter, tested starter and it worked..... scary https://www.youtube.com/watch?v=qqsZ8nxACYo | ||
Expert 5K+ Posts: 9663 Location: So. Cal | If you paint outside, I've had great results by painting under an easy up as long as there is no wind. It keeps any crap from falling into your paint and keeps the direct sunlight off of your parts. | ||
Expert 5K+ Posts: 5006 | yeah ive never had that happen before... was like a tiny blob... should be okay now. i think im done painting i hope i am.
Edited by mikes2nd 2020-10-02 6:58 PM | ||
Expert 5K+ Posts: 5006 | wrap pics... putting exhaust in the car now.. had to order parts to finish wiring.. uhg (wrap1.jpg) (wrap2.jpg) Attachments ---------------- wrap1.jpg (222KB - 336 downloads) wrap2.jpg (220KB - 336 downloads) | ||
Expert 5K+ Posts: 5006 | Engine harness is complete... https://www.youtube.com/watch?v=_qbyytIvXvo finishing up dash... | ||
Expert 5K+ Posts: 5006 | Going to go for a test fire this weekend... Got hoses... open headers though Still waiting on pipes off header. Test my electric fuel pump for leaks maybe tonight... get gas and antifreeze in it... https://www.youtube.com/watch?v=PlH3sMph2mA | ||
Expert 5K+ Posts: 9663 Location: So. Cal | I don't recommend doing that. Get your exhaust all connected with mufflers and then setup your motor for breaking in the cam. Otherwise you risk ruining your lobes by doing any unnecessary startups. The first startup is pretty critical and you don't want to do it more than once if you can help it. Correct me if you are running a roller, but I didn't think so. Right before I run it, I pull the distributor and leave the intake & valley cover off. Then run a drill on your oil pump. Once you see a good amount of oil flowing over your cam, turn the motor over with the starter for a good while, while still running the drill on the pump. This seems to do a great job of avoiding the initial grind. Then put it together and start it up to break in the cam. Edited by Powerflite 2020-10-23 3:25 PM | ||
Expert 5K+ Posts: 5006 | yeah i was thinking about that... not rollers.. It been 8 months probably since i prelubed the engine.. hmm, i have bumped the engine over a little.
I was thinking just seeing if she will fire for a couple a seconds... Edited by mikes2nd 2020-10-23 3:37 PM | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | Ha, man, your video reminds me of going over wiring diagrams until my eyes rolled back in my head. You'll have a breakthrough when your first circuit is tested and works! Mine was the dome lights. Everything else will fall together quickly after that. Wiring your own car is SO much work... but very satisfying once you're done. Keep at it, you're close! Edited by 57burb 2020-10-23 8:21 PM (20180303_115308.jpg) (20180308_221627.jpg) (20180318_223139.jpg) (20180319_225456.jpg) (20180331_173444.jpg) Attachments ---------------- 20180303_115308.jpg (129KB - 331 downloads) 20180308_221627.jpg (113KB - 318 downloads) 20180318_223139.jpg (153KB - 318 downloads) 20180319_225456.jpg (156KB - 317 downloads) 20180331_173444.jpg (160KB - 338 downloads) | ||
Expert 5K+ Posts: 5006 | wow in the trunk? Hmm that's a loty to move to the dash I got my headers welded up, still have to finish up the exhaust. My exhaust is custom, i wasnt thrilled with the exhaust I recieved though. Minor glitch from classic exaust I have to finish welding up exhaust, got the radiator hoses in. | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | Yep, it wasn't any issue at all. I did use both rocker channels. They have plenty of room though, even with power windows and solenoids for the shaved door handles. It really keeps the engine bay and under dash area neat and tidy. It did make the trunk space somewhat smaller especially since I upholstered it. When you get the exhaust wrapped up, let's see a video of it running! | ||
Expert 5K+ Posts: 5006 | this exhaust is a pita... stupid things spiral around the darn torsion bars... (exhaust1.jpg) (exhaust2.jpg) Attachments ---------------- exhaust1.jpg (235KB - 306 downloads) exhaust2.jpg (227KB - 313 downloads) | ||
60 Imp |
Location: North Australia | pipes look good except for the wrinkly curve around the bar. I thought they all go around the torsion bars? Did you do it in 2 inch Mike?Here is 300 C pic I found. (exhaust 300.jpg) Attachments ---------------- exhaust 300.jpg (51KB - 319 downloads) | ||
Expert 5K+ Posts: 5006 | yeah those wrinkles are from the one bend and the weld. its all custom, the 392 trans makes things tougher also, the hemi is alot tighter All two inch. | ||
Expert 5K+ Posts: 5006 | Okay had a leak in the gas tank... never trust em... couple pin holes in the strap area... that set me back... Fixed it, put the tank back in it. 93 octane.. put 3 gallons in it, test fired the fuel pump.. its pretty quiet... got gas... tried starting... car wasn't in neutral
would not fire at first... had the wires one position off(after i got the timing light out, showed spark, i knew i had gas). I had been playing with the wires so many times I must have got it off a position.. So after messing it fired, sounds great... I have a leak at the water cross over... one freeze plug i had over tightened and the nut broke off...got to pull that and replace after i order a new one... AND the tranny puked trans fluid.. I have NO engine oil leaks which im very grateful for... rear main seal seems to be good, i was very careful about that one. I will drop the tranny pan if I have to and redo it. Ill order a new oil pan gasket, i may have over tightened. I think it was cork... real slight drop, couple drips per day. Edited by mikes2nd 2020-11-21 6:20 PM | ||
Expert 5K+ Posts: 5006 | https://www.youtube.com/watch?v=QPOnHTt051M | ||
Expert 5K+ Posts: 5006 | how in the hell do you get the transmission breather little cap off the back? with the trans in the car? Its crimped on... i tried to wedge it a bit... | ||
58coupe |
Expert Posts: 1740 Location: Alaska | Why do you want to remove the breather cap? Is it leaking fluid there? | ||
Expert 5K+ Posts: 5006 | it spit out oil from the transmission fill tube.. i heard it can do that, i might try some air and see if it comes out, the cap is lloose. I wont put hard air on it, just some gentle pressure. I got the freeze plug out, ill need to buy a new set. Kind of annoying. Those hot heads copper ones did work well, i must have over tightened the one and the nut broke off. I fixed the water filler leak and put some sealant on the water pump bolt. That should fix the leaks, no oil leaks, just the water leaks... Anyone else experience full oil pressure on startup? i have 80 psi. I do have a 20% more high flow oil pump(melling). I am a little worried about the oil filter so i am going to get another one, i talked to hot heads about recommended filters. | ||
Expert 5K+ Posts: 9663 Location: So. Cal | Congratulations on getting the motor running! Just use the filter you have to do the cam break in. Change it to something else afterward. The o-ring freeze plugs with the T-bar work well, but can seep if the surface is pitted. But they will never pop out on you, which is what I like about them. The trans in my Fireflite did the same thing you are describing. I drove it around the block as it spewed out the tube. Stopped the car and shut it off. Then I was able to refill it without the air bubble problem. Not sure what the proper procedure is. | ||
Expert 5K+ Posts: 5006 | thanks yeah i asked someone else they said it sometimes can do that when empty, ill see if it settles down. Something about it being in gear possibly? I started the car up in the air but I don't think the wheels spun. Maybe you need to get it into gear quick Yeah ill yank that filter off quick once i get a 10-15 minute break in done, that oil pressure is at the back of the block so I guess that mean im getting good pressure where it needs to be. I have comp cams zinc oil in the car. this thing seem stout... no fan, hot heads intake with the avs2 carb... very responsive also(as you can see). I have a small exhaust leak i need to address. I didn't touch the carb... just started it I spent a lot of time learning wiring.. its a joke once you spend the time to learn it once. I did a lot of customization though. That oil pressure safety switch alone was probably a day f'ing around with it. Its about prep and planning with these wiring kits, get it in the right place the first time, but in the end pretty simple. Get all the parts you need ahead of time... making changes to the wiring sucks... order from amazon... wait 2 days... order from amazon wait 2 days... order from amazon wait 2 days... i still have to "map' the dash now. Edited by mikes2nd 2020-11-24 8:54 AM | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | Congrats man! Sounds great! And that oil pressure is plenty stout. Is that cam already broken in? You don't have to wait two days for electrical parts to come from Amazon, there's plenty of other stuff to do. The transmission vent cap doesn't usually need to come off. I think it will pop off if you pry on it. If you really want, I have three iron TFs in my shop and I can take a look at them the next time I'm down there to see if there's a way to get it off without damaging the cap. Dang, you cut the e-brake cables off that rear? Gonna be hard to make that functional again. | ||
Expert 5K+ Posts: 5006 | i had the ebrake cable in the car, original. I broke the cam in with comp cams zinc break in oil, 20 minutes on it, ill swap it out, put new oil in with zinc hope and pray My transmission was fine after letting it settle down, power steering "sucked" up a quart so i stuck another in. Got all the leaks fixed. Got some 16 inch rims and rubber, tried portawalls for fun and my low rider spinners(I want to put the knights head on them somehow). They look pretty good and pretty fat. (rimnew.jpg) Attachments ---------------- rimnew.jpg (243KB - 302 downloads) | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | Nice! It's really coming together now. Keep an eye on those portawalls. If your radials have a 'pooge' at the bottom, thousands of cycles of flexing in and out will stretch the whitewall to the point they flop all around while going down the road. But they usually work okay. I like those 'Polara' like caps. Hope you can figure out how to get a knight's head on there. | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Perhaps the preahers collars would work on low profiles, but check the tire sidewall often as there will be a groove sawed by the edge of the white rubber and the white will get really nasty grey brown very soon. Don't ask Me how I know ?????? | ||
Expert 5K+ Posts: 5006 | the portawall is actually just up on a ridge on the bottom of the sawed edge so they arent sitting on the saw section, the portawalls seem pretty stout, they aren't flimsy so who knows I really just wanted to experiment. I am still considering a final option of a chromed concave steelies with the knights spinner on it. I figured i got into this whole set of rims/tires/portawalls for 425$, tires free, portawalls 75, rims 250, caps 100$ so its a good trial set of rims/tires. | ||
