AC freon capacity
59 in Calif
Posted 2017-03-13 9:42 PM (#535891)
Subject: AC freon capacity
50010010010010025
Hey Guys, Getting ready to start on the AC sys. I have a rotorary comp from Bouchillon. the piston type was too tall and couldnt close the hood. the condensor came from the Dodge motor home that I took the eng out and put in wife 59 Dodge. Summit Racing has a nice looking under dash unit from Vintage Air. ? is how do I know how much freon R134 to put in it ? Thanks, Jerry
Posted 2017-03-14 4:09 PM (#535948 - in reply to #535891)
Subject: RE: AC freon capacity
2000500100
Most Vintage Air units require 1.8 lbs. of R-134
59 in Calif
Posted 2017-03-14 9:48 PM (#535967 - in reply to #535891)
Subject: Re: AC freon capacity
50010010010010025
I'm guessing the condensor size would affect the sys capacity. Are most automotive condensors about the same size ? this one completely covers the rad. Do I still need to add that can of oil with a rotary compressor ? Thanks, Jerry
Posted 2017-03-15 5:16 PM (#536008 - in reply to #535967)
2000500100
Condensor size has little bearing on system capacity. A new Sanden compressor is charged with all the oil the system will need.
Search for anything on eBay!
