Astrodome Dash Turn Signal Stalk Install
J97_Imperial
Posted 2017-03-08 1:09 AM (#535424)
Subject: Astrodome Dash Turn Signal Stalk Install
1002525
Hey Guys,
On my 1962 Chrysler (I would assume it is the same for 60 and 61 as well) I am trying to reinstall the turn signal stalk located underneath the pushbuttons. The stalk was never in place correctly since I've owned the car and I cant really just pop it into place like I would assume it should. Does anyone have any advice on how to install the stalk correctly so I can have turn signals?
Jacob
Posted 2017-03-08 1:24 AM (#535425 - in reply to #535424)
Subject: Re: Astrodome Dash Turn Signal Stalk Install
500050002000100025
The knob is screwed onto the lever with a locking screw - the lever is part of the switch and can not be demounted. It seems that your lever broke off?
Upload some photos, it will be more easy to understand and help you......
J97_Imperial
Posted 2017-03-08 1:43 AM (#535427 - in reply to #535425)
1002525
I will tomorrow morning. If that is the case, I will probably have to fix the lever i guess.
Jacob
