1957 Plymouth Sport Suburban "V800" (or not)
Jump to page : 1 2 3
Now viewing page 3 [50 messages per page]
Jessica
Posted 2017-06-05 6:19 PM (#541582 - in reply to #533886)
Subject: RE: 1957 Plymouth Sport Suburban "V800" (or not)
10002525
My suspension is almost a wrap. Setting the torsion bars back in tonight. Then it's on to the transmission.
Edited by Jessica 2017-06-05 6:21 PM
(IMG_1050.JPG)
(IMG_1051.JPG)
(IMG_1052.JPG)
Attachments IMG_1050.JPG (177KB - 176 downloads)
Attachments IMG_1051.JPG (155KB - 167 downloads)
Attachments IMG_1052.JPG (136KB - 171 downloads)
Jessica
Posted 2017-06-08 11:56 AM (#541788 - in reply to #533886)
10002525
Torsion bars are back in the wagon as of last night. I forgot what a PITA that job is. I'm sure I'll need to adjust and level everything out once my motor is bolted up. I painted my master cylinder last night as well. Looks like it will be a snug fit below the booster, but it will work. Once that's bolted up I can run my new lines. More updates this weekend.
Posted 2017-06-08 12:20 PM (#541790 - in reply to #541788)
50002000200050010025
You might consider running a master with a remote reservoir. That is what I am using. It will make working on it so much easier. I am using an iron master from a guy on Ebay, but there are aluminum Mopar masters too. They are all 2 bolt and require an adapter that is available from Mopar Performance.
Jessica
Posted 2017-06-09 9:42 AM (#541856 - in reply to #533886)
10002525
I actually found another master on the shelf in the shop that will work better than the one I originally intended to use. This was formerly a drum to drum master, and we converted it to disc to drum. I have decent clearance now. Still have yet to run my lines and make a bracket for my SSBC proportioning valve. Perhaps this weekend that'll get done.
(IMG_1065.JPG)
Attachments IMG_1065.JPG (102KB - 174 downloads)
Posted 2017-06-09 12:37 PM (#541861 - in reply to #533886)
Yeah, that is the typical one that most people use. It works, but is more difficult to fill and work with. This is the one I am using, but I am not using this reservoir. I have an aluminum one that is skinnier and looks better.
(Reservoir.jpg)
Attachments Reservoir.jpg (157KB - 153 downloads)
Jessica
Posted 2017-06-10 4:49 PM (#541905 - in reply to #533886)
10002525
Awesome. I'll see how this set up works for now. I can always change it later. I just want to be done with the front end already. I'm over it.
Brake lines are in, and I think I am finally ready to put the motor in.
(IMG_1075.JPG)
(IMG_1076.JPG)
(IMG_1077.JPG)
Attachments IMG_1075.JPG (115KB - 167 downloads)
Attachments IMG_1076.JPG (148KB - 160 downloads)
Attachments IMG_1077.JPG (173KB - 175 downloads)
