361 Oil Pump Driveshaft Question
J97_Imperial
Posted 2017-02-12 12:56 AM (#533809)
Subject: 361 Oil Pump Driveshaft Question
1002525
Hey Guys,
So I am working a 361 out of my Newport and I have what I think is an issue. Firstly, when I was disassembling this extremely neglected engine (hasn't run since 89 and was in a scrapyard for some time) the slot in the distributor itself where it mounts to the oil pump driveshaft broke off. No problem, I have an extra driveshaft from the 383 that I have just in case i need to swap engines. However, when I was trying to get the old driveshaft out, it was very difficult. I ended up having to use a pipe wrench and screwdrivers and a hammer However, I did not damage the bushing at all which is good news. When I went to put the replacement driveshaft in today, it would go in about halfway and stop. (I did lube the driveshaft with some motor oil so if that is the problem please tell me) It seemed like it was actually forming a seal with the bushing and trapping air under the driveshaft. I was wondering if there was some sort of bleed bolt or whatnot on the oil pump itself so that the air can bleed while I place the entire driveshaft in.
All help is greatly appreciated
Thanks
Jacob
BigBlockMopar
Posted 2017-02-12 5:07 AM (#533815 - in reply to #533809)
Subject: Re: 361 Oil Pump Driveshaft Question
20001000500252525
Bushings need to be reamed to size when installed.
Maybe someone replaced it sometime ago and never did this.
You can cut a sharp longitudinal groove in the old driveshaft and use it as a reamer perhaps.
I would have a close look at/inside the oilpump to find out why the driveshaft tip sheared off.
J97_Imperial
Posted 2017-02-12 11:34 AM (#533831 - in reply to #533815)
1002525
BigBlockMopar - 2017-02-12 4:07 AM
The driveshaft tip didn't shear off, it was the distributor tip. They were seized together from sitting with the hood up in a scrap yard
Jacob
Posted 2017-02-12 4:37 PM (#533849 - in reply to #533815)
20001000500100100252525
BigBlockMopar - 2017-02-12 2:07 AM
Actually, correct installation requires a special burnishing tool, reaming is not recommended.
Easiest way to remove a stubborn intermediate shaft is to remove the oil pump first, then drive the shaft out from the bottom. A varnish ridge on the shaft will make shaft removal difficult even with a proper size bushing.
J97_Imperial
Posted 2017-02-12 10:10 PM (#533866 - in reply to #533849)
1002525
57chizler - 2017-02-12 3:37 PM
Shaft is out so should I remove the oil pump before installing the new one?
Jacob
Posted 2017-02-13 1:57 PM (#533934 - in reply to #533866)
I would remove the pump to be sure the reason the shaft won't go in is the bushing and not the pump.
J97_Imperial
Posted 2017-02-13 7:27 PM (#533966 - in reply to #533934)
1002525
57chizler - 2017-02-13 12:57 PM
Actually just got done removing the pump. Found out the reason I was having so much trouble was a buildup of sludge. Cleaned it all out and it is fine now. I have the driveshaft set to TDC and will reinstall pump tomorrow.
Jacob
