Location: Washington State, the wet side | Nice Cross ram set (long ram's) including exhaust manifolds, rebuilt carbs, original air cleaners (someone cut the sides off them, for more airflow??)
linkage, needs minor cast iron welding on one of the heat riser tubes. No rot in the bowls. A couple of the mounting bolts for the tubes in the exhaust manifold was broke off.
The story I got when buying them a few years ago was that the original owner did not like how cold blooded they were and had the dealer replace them with dual quads. Some of the original stickers are still on the tubes so I don't doubt the story to be true. Missing the center pieces that mounts to the heads and the cross tube. Other than that it is complete. $3,500 |
