Door window weatherstriping
59 in Calif
Posted 2017-01-31 11:21 PM (#532849)
Subject: Door window weatherstriping
Hey Guys, Are the 57 - 59 Dodge and Ply 2 dr sedan doors the same ? The reason I ask is: I'm installing the door window weatherstriping. 59 Dodge 2 dr sedan. I have the wing window seal installed and that big U shaped seal that mounts into the door window opening and seals the window at the top and rear end of the window. There is also a flat seal that mounts horizontally to the door and another one to the inside window moulding that seals the bottom of the window. Problem is that seal on a 2 dr sedan makes a 90 degree turn vertically at the rear end of the window opening to match the door window opening. Restoration Specialties call this seal a ' belt weatherstrip ' and they have a kit which has 1 inner and 1 outer, for a 57 - 59 Ply 2 dr sedan. Soooo, does the Dodge and the Ply use the same length door window glass ?? There is no listing for the Dodge, only the Ply. If the glass is the same length as the Dodge,,, Great I'l order them. Otherwise I'm in a world of *hit again! Thanks, Jerry
