Car sits lower on the drivers side. Need suggestions Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Beltran |
Expert Posts: 1730 Location: Michigan | Penny is a 55 Chrysler Windsor that is slightly modified. See the signature below. I have had this issue with her since I got her. The car sits 1 - 1.5" lower on the drivers side (in the rear) then the passengers side. Obviously this is worse when I sit in the car. So I got a set of stock rear springs from Springs & Things and replaced the tired originals. It took about 6 months but it started to lean to the drivers side again. I tolerated it for a few years. Last year I replaced the rear axle with a 69 Roadrunner 8.75 axle after moving the spring perches out to the proper distance to align with the springs. I also got new Eaton springs that had an additional leaf over the S&T set. Again, about 4-6 months after the install the car is leaning to the driver side 1 - 1.5". So disassembled the springs from the axle again. I started on the drivers side and noticed that once the tension was off the U bolts, the spring dropped about 4 inches. The axle was floating above the spring. This seemed to be due to the passenger side being still firmly attached. Once I loosened the passenger side the axle came down to sit on the drivers side spring perch. /hmmm... things that give you pause... I added another leaf to the drivers side, it now has 7 leafs, and reassembled the springs and axle. After lowering the car it looked fine. I then sat in it to pull it back into the garage, got out and noticed that it is again, sitting 1.5" lower on the drivers side. Please point out what stupid thing I keep doing that causes this. I have no ego to speak of so I won't be offended by even the most basic of questions. | ||
Shep |
Expert Posts: 3396 Location: Chestertown, NY ( near Lake George) | How about a weak lt ft spring or too strong a rt ft spring. Also are the spring isolators in place in the front? | ||
Beltran |
Expert Posts: 1730 Location: Michigan | Yes Shep I have considered that as well. However these were changed with the rear springs and the isolators are in place on both sides. If it leans in the front it is not perceptible. I have not used a tape measure though to check. It lines up evenly on the Tire to fender check. | ||
Shep |
Expert Posts: 3396 Location: Chestertown, NY ( near Lake George) | Pain in the ass here but swap rear springs, see what happens. Edited by Shep 2017-01-31 9:55 AM | ||
StillOutThere |
Location: Under the X in Texas | Any evidence the car ever had a serious accident? Might want to get a frame dimension chart off ebay and have a body shop with a frame machine see if there is some twist in the frame causing the springs a headache. Only thing I can think of. | ||
Expert 5K+ Posts: 9903 Location: Lower Mainland BC | This might come off rude but are you a "husky" guy? 200 lbs is probably not going to sag the driver's side much but 250 or 300 would very like cause a sag. | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | I have been wrestling with the same type of problem - Chrysler '60, the height difference is roundabout 3/4" lower on the drivers side. I have tried with spacers between the leaf spring and the rear axle - no change. I have tried with longer shackles on the drivers side - no change Measurement from for example under side of the rockers are identical if the body rests on floor stands. The front end height is adjusted to the correct measurements. I suspect that one of my torsion springs are weaker and that I must compensate with the front end height. | ||
Beltran |
Expert Posts: 1730 Location: Michigan | Dave, I am about 210. I would guess that this would happen over years of regular use. But 6 months after you install them and only drive the car occasionally? The car is a 60k mile vehicle. I have had it apart and I know there has never been any accident damage. I will continue to ponder the possibilities. | ||
55 Dodge |
Veteran Posts: 164 Location: ST. Stephen NB Canada | Mark, I have had this issue with my 55 Dodge Royal, but mainly in the front drivers side. I put new front Coils from Springs N Things, & 5 leaf( stock was 4 even though it is a Hemi) springs in the rear. Little or no change. I have a truck battery ( 6 volt) on that side & when I took it out, the body came up 1/4 inch. Also the gas tank is more on that side as well. Not sure if that contributes, but I never found any thing conclusive.ure | ||
Beltran |
Expert Posts: 1730 Location: Michigan | I am beginning to wonder if the bushings are binding or something. | ||
