Trans Doesn't Kickdown
FINS!
Posted 2017-01-24 12:47 PM (#532204)
Subject: Trans Doesn't Kickdown
50010010010010025
On my 57 Imperial which has a stock, rebuilt 392, the trans is not shifting down until I get to a certain speed, about 25-30, then it shifts. As I go faster--10, 15, 20, the RPM will go up and up until it shifts and goes back down to a normal RPM. But if I floor it from a standstill it shifts fine. Ideas? Transmission linkage need adjusting? Thanks
Posted 2017-01-24 1:26 PM (#532207 - in reply to #532204)
Subject: RE: Trans Doesn't Kickdown
20001000500100100252525
Probably needs a linkage adjustment due to sagged rubber mounts or missing bushings in the linkage. Check pages 9 and 10 in the link below:
http://www.imperialclub.com/Repair/Lit/Master/129/index.htm
FINS!
Posted 2017-02-08 11:56 AM (#533521 - in reply to #532204)
50010010010010025
Thanks, it appears to be adjusted correctly but I am not 100% positive. Some of the bushings are pretty sorry looking, any idea where to get new ones? Also if anyone has made this adjustment and could offer some tips that would be great.
