Serpentine Belt Drive Kits
Posted 2017-01-09 12:42 PM (#530905)
Subject: Serpentine Belt Drive Kits
50001000100100100100252525
http://www.sdconcepts.com/serpentine_belt_drive_kits.html
Anyone use these for your big block?
https://www.facebook.com/Superior-Design-Concepts-606715996023750/
http://www.forbbodiesonly.com/moparforum/threads/true-serpentine-be...
Edited by mstrug 2017-01-09 12:45 PM
Posted 2017-01-09 1:35 PM (#530910 - in reply to #530905)
Subject: RE: Serpentine Belt Drive Kits
200010005001001002525
I've seen them before and noticed that they turn the water pump backwards. How does that work?
Posted 2017-01-09 4:38 PM (#530932 - in reply to #530905)
Subject: Re: Serpentine Belt Drive Kits
I'm sure you get a 'Marine' left hand water pump with the kit.
BigBlockMopar
Posted 2017-01-10 2:59 PM (#531021 - in reply to #530905)
20001000500252525
Doesn't matter much for the pump design, as long as you don't use a (modern/aftermarket) waterpump with spiralled/directional vanes.
Water is flown outward by the pump and creates some vacuum in the center, so there's always a pressure difference that promotes circulation.
