Adding Pics
   Forward Look Announcements -> Frequently Asked QuestionsMessage format
Flite58
Posted 2016-11-30 8:58 AM (#527537)
Subject: Adding Pics
I was trying to put up a post for my car
I need to add pics.
There is nowhere an Add Pictures / attachments.
It does say at the bottom "attach a file after posting"
so do I have to post the text then add the pics afterwards now, I don't remember it that way before.
I don't want to put up a bunch of text then not be able to add anything if that doesn't work.
Am I missing something obvious?
Whats the max size per pic?
Maximum # of pics per post?
Thanks in advance to anyone who helps out.
Posted 2016-11-30 9:58 AM (#527540 - in reply to #527537)
Subject: RE: Adding Pics
500050002000100025
Just a dot will do as a post, then hit attach a file and browse for your picture.
If it's too big for to upload then you'll get error with the maximum file size
Flite58
Posted 2016-11-30 10:23 AM (#527542 - in reply to #527537)
Subject: Re: Adding Pics
Thanks
That's the problem , there is no "add a file" anywhere as I can see and I can't post a pic to show you
Only "attach a file after posting" I guess I'll try that and see if I can add them
otherwise it will look silly with no pics
Posted 2016-11-30 10:25 AM (#527543 - in reply to #527537)
500050002000100025
Yes there is, but it's called "Add / Remove attachments" if you hit the "Edit button" in a thread already posted.
In a new thread it's called "Attach a file after posting"
Flite58
Posted 2016-11-30 10:32 AM (#527544 - in reply to #527537)
OK
Gotta go out now I'll have a go later
Thanks again
jitu89
Posted 2018-06-25 2:17 AM (#565563 - in reply to #527537)
New User
First check the file check it is allowing and try directly sharing by link.
Posted 2018-06-25 8:50 PM (#565616 - in reply to #527537)
500020002000500100
Please avoid links if at all possible. Links die after a while, and then the whole site is filled with dead links. Also, max photo size is 250kb in most places. In the member rides area, it is 500kb. Photos must be in .jpg format. Macintosh systems that use .jpeg won't show the picture so rename them to the .jpg extension. If you click the "attach file after post" box, it will take you to the file attachment process right after posting your text.
Edited by Powerflite 2018-06-25 8:52 PM
