Parting over 40 FL cars Jump to page : < ... 14 15 16 17 18 19 20 21 22 > Now viewing page 20 [50 messages per page] | View previous thread :: View next thread |
Forward Look Swap Meet -> Parts Cars - VEHICLES BEING PARTED OUT | Message format |
Chrysleri |
Regular Posts: 62 Location: Nokia, Finland | Ok. Thanks anyway | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | Just picked up a '57 New Yorker, has rust free trunk floor and nice trim- 4-door hardtop for parts. | ||
springsweptwing |
Elite Veteran Posts: 1140 Location: Blackpool, United Kingdom. | Hi John, How much would the trunk floor be including shipping to Florida? Thanks Paul. | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | springsweptwing - 2017-09-14 12:26 PM Hi John, How much would the trunk floor be including shipping to Florida? Thanks Paul. Hi Paul, The trunk floor, complete with tailpanel, cut just beyond each seam, will be $500, Shipping to FL. will be around $400, if you're interested, I can get a shipping quote. ---John | ||
springsweptwing |
Elite Veteran Posts: 1140 Location: Blackpool, United Kingdom. | PM sent John, thanks Paul. | ||
ply57nz |
Regular Posts: 94 Location: New Zealand | The hood letters arrived today John, Great pieces and I'm very happy with them. Thanks again for all your help. Cheers Norm Edited by ply57nz 2017-09-20 1:19 AM | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | ply57nz - 2017-09-19 8:38 PM The hood letters arrived today John, Great pieces and I'm very happy with them. Thanks again for all your help. Cheers Norm Thanks for letting me know, Norm! ---John | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | John, I need sheetmetal just below the rear window along the trunk...where my trim below the window was sitting, it is rotted thru...not sure how that could even be cut,,,any ideas? Thanks, billy | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | billy - 2017-09-30 7:33 AM John, I need sheetmetal just below the rear window along the trunk...where my trim below the window was sitting, it is rotted thru...not sure how that could even be cut,,,any ideas? Thanks, billy I'll have a look to see that it's good. Your car is a four door HT, Correct? ---John | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | Hi Billy, I do have the rear window channel in nice condition, how much of it do you need? ---John | ||
brdtee |
Veteran Posts: 243 Location: Pieksamaki, Finland, Europe | I'm looking for 1957 Chrysler 4d Sedan parts such as.. * Sill plates in good condition. Mine have been somewhat corroded. * The chrome molding that runs on the door panel above the black bottom part, one is enough. * P/S pump for 354 poly. * Solid and straight upper RH molding of the Windsor color sweep panel. | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | brdtee - 2017-10-03 9:43 AM I'm looking for 1957 Chrysler 4d Sedan parts such as.. * Sill plates in good condition. Mine have been somewhat corroded. * The chrome molding that runs on the door panel above the black bottom part, one is enough. * P/S pump for 354 poly. * Solid and straight upper RH molding of the Windsor color sweep panel. I have four good sill plates, the best driver side front has a smalls pot of corrosion at the lower edge by the carpet, but the rest is good. I have the lower doorpanel molding from a Windsor, but they are specific to driver or passenger sides, so I'll need to know which you need. Upper quarter panel molding, I'll also need to know which side is needed, I have both. ---John | ||
brdtee |
Veteran Posts: 243 Location: Pieksamaki, Finland, Europe | big m - 2017-10-04 1:21 AM brdtee - 2017-10-03 9:43 AM I'm looking for 1957 Chrysler 4d Sedan parts such as.. * Sill plates in good condition. Mine have been somewhat corroded. * The chrome molding that runs on the door panel above the black bottom part, one is enough. * P/S pump for 354 poly. * Solid and straight upper RH molding of the Windsor color sweep panel. I have four good sill plates, the best driver side front has a smalls pot of corrosion at the lower edge by the carpet, but the rest is good. I have the lower doorpanel molding from a Windsor, but they are specific to driver or passenger sides, so I'll need to know which you need. Upper quarter panel molding, I'll also need to know which side is needed, I have both. ---John * Sill plates sound good. Mine have quite bad corrosion on the outer edges, especially the rear door ones. * Do you have full door panels as well? Mine are trim code 055. Not beyond repair but minor damage. If yours would be same color and in better shape, they could be interesting. Also interested in front door inner handles if the vinyl part and the padding is good. * I guess moldings for both front doors would be needed. If only one, then the passenger side. * Upper color sweep quarter panel molding would be the passenger side as well. I have a shipping address in U.S., my friend can deliver the goods overseas from there. | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | brdtee - 2017-10-07 9:39 AM big m - 2017-10-04 1:21 AM brdtee - 2017-10-03 9:43 AM I'm looking for 1957 Chrysler 4d Sedan parts such as.. * Sill plates in good condition. Mine have been somewhat corroded. * The chrome molding that runs on the door panel above the black bottom part, one is enough. * P/S pump for 354 poly. * Solid and straight upper RH molding of the Windsor color sweep panel. I have four good sill plates, the best driver side front has a smalls pot of corrosion at the lower edge by the carpet, but the rest is good. I have the lower doorpanel molding from a Windsor, but they are specific to driver or passenger sides, so I'll need to know which you need. Upper quarter panel molding, I'll also need to know which side is needed, I have both. ---John * Sill plates sound good. Mine have quite bad corrosion on the outer edges, especially the rear door ones. * Do you have full door panels as well? Mine are trim code 055. Not beyond repair but minor damage. If yours would be same color and in better shape, they could be interesting. Also interested in front door inner handles if the vinyl part and the padding is good. * I guess moldings for both front doors would be needed. If only one, then the passenger side. * Upper color sweep quarter panel molding would be the passenger side as well. I have a shipping address in U.S., my friend can deliver the goods overseas from there. The door panels are all in poor condition, as are the armrest pads. I do have the door trim pieces, however. ---John | ||
luedi |
Extreme Veteran Posts: 538 Location: Hamburg-Germany | hi john I need the throttle torque shift between carburetor and linkage on the fire wall first pic it s the shift on my belvedere sec pic it s from the diplomat missing the shift (75.JPG) (74.JPG) Attachments ---------------- 75.JPG (175KB - 740 downloads) 74.JPG (176KB - 761 downloads) | ||
brdtee |
Veteran Posts: 243 Location: Pieksamaki, Finland, Europe | big m - 2017-10-18 5:14 PM The door panels are all in poor condition, as are the armrest pads. I do have the door trim pieces, however. ---John Sent you e-mail last week, did it come thru? I've had some issues with mails disappearing to cyberspace here in my end. -Heikki- | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | brdtee - 2017-10-27 3:41 AM big m - 2017-10-18 5:14 PM The door panels are all in poor condition, as are the armrest pads. I do have the door trim pieces, however. ---John Sent you e-mail last week, did it come thru? I've had some issues with mails disappearing to cyberspace here in my end. -Heikki- I'll double c heck on that, and let you know. | ||
GSMDodge |
Member Posts: 17 Location: Knoxville, TN | John, I need several parts from a '60 Matador or Polara. They include front clip parts between the hood and front bumper (emblem, grille, shield, skirt), two 14" hubcaps (4 bar; spinner?), and the aluminum deflectors on each rear quarter panel (in front of the rear wheels). Let me know if you have at of these parts or where I might find them. Thanks, Ken Cunningham (865) 607-0406 | ||
floyd066 |
Extreme Veteran Posts: 347 Location: Ocean Park, Washington | Looking for a nice turn signal stem for a 55-56 Chrysler or Desoto. | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | floyd066 - 2017-11-17 9:18 PM Looking for a nice turn signal stem for a 55-56 Chrysler or Desoto. I have one with decent chrome in a '56 Chrysler, $30 plus shipping. ---John | ||
floyd066 |
Extreme Veteran Posts: 347 Location: Ocean Park, Washington | can you shoot me a picture? | ||
Paperweightnate |
Member Posts: 5 | Big M! 1955 Chrysler Windsor, currently looking for the following: Windshield, New Yorker exterior trim package, Front drivers door, Front drivers door handle. Thanks! | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | Paperweightnate - 2017-12-06 3:00 PM Big M! 1955 Chrysler Windsor, currently looking for the following: Windshield, New Yorker exterior trim package, Front drivers door, Front drivers door handle. Thanks! I'm assuming your car is a 4-door sedan. I have complete New Yorker trim, A good left front door, used windshield. I did not have the door handle. ---John | ||
RDP |
Elite Veteran Posts: 1048 Location: PL / EU | hi John! '56 Chrysler 2dr door latches? | ||
luedi |
Extreme Veteran Posts: 538 Location: Hamburg-Germany | hi again i need this chrome trim for the rh side vent window hardtop pic show the lh side greetings jan (113.JPG) (115.JPG) (117.JPG) Attachments ---------------- 113.JPG (181KB - 695 downloads) 115.JPG (185KB - 692 downloads) 117.JPG (186KB - 663 downloads) | ||
Fick4fun |
Veteran Posts: 135 | Hey big m I was wondering if you had a hood release cable and the bracket that holds it to the dash for a 1963 imperial. I mainly need the bracket my cable is fine but the bracket center pulled out. Thanks brandt | ||
Justinsane |
Location: Binghamton NY | Big M, I was wondering if you have any 56' Plymouths. I need a steering wheel horn ring (full circle ring) and the little strips of stainless molding that were on the belvederes, below the door on the rocker panels. I've been searching for these for years, thought i'd give this site a try. Thanks.. | ||
69coronet |
Veteran Posts: 298 Location: Nashville, TN | John, I saw a thread somewhere that you had 4 1960 4 door Imperials you were parting out. Do you have a set of door panels in good shape, and do you have any of the "CROWN" letters that are on the front fenders? Ron | ||
Metalshop16 |
Member Posts: 41 Location: Cognac , S-W of France | Hi John Wanted a steering column jacket and the horse shoe bracket for my 58 Savoy ( P/S , TF ).............? Thanks | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | Metalshop16 - 2018-04-16 11:14 AM Hi John Wanted a steering column jacket and the horse shoe bracket for my 58 Savoy ( P/S , TF ).............? Thanks Hi Jerome, I have a power steering mast jacket for your '58 Plymouth in good shape, as well as the horseshoe bracket. $80 plus shipping for all. I do not have the turn signal switch. Please let me know if you are interested, John | ||
Metalshop16 |
Member Posts: 41 Location: Cognac , S-W of France | Ok John .......PM | ||
Marc A |
Location: Flamborough Ontario Canada | Hello. I have a 62 windsor 4 door sedan. I would like to find a set of stainless rocker trim. Windsor, Newport, new yorker. Need all of it, the pieces at the wheel wells and the long pieces that run the length of the rocker. I would also like to find a 62 New Yorker grill. And I'm looking for a set of long ram air breathers. Thanks. Marc | ||
johnnybiz |
Veteran Posts: 174 | hello I have a 58 Windsor 4 door im looking for solid lower quarter panels for both sides | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | johnnybiz - 2018-05-14 5:12 PM hello I have a 58 Windsor 4 door im looking for solid lower quarter panels for both sides I have some 4-door quarters that have good wheel openings, but after blasting, there will be some pinholing at the very bottom behind the wheel openings. ---John | ||
FinnDesoto |
Member Posts: 9 | hi, I'm looking for a complete driver side front ventilation window. My car is 1956 Desoto Fireflite 2dr Ht Also a hood lip molding. | ||
Mackey58 |
Member Posts: 21 Location: port leyden ny | Hello, looking for rust free 58 plymouth panel below trunklid. Including the lower ends of the quarters and rear body mounts. Also need the panel between the hood and windshield that holds the vent grill. | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | I* have some that are completely rust free, but I sell them with the complete trunk floor section. I do have one tail panel and reasr support that has no rust on the side you see, but there are several holes beneath that will need work. I also have a good top of the cowl. ---John | ||
sidesho_bob1961 |
Expert Posts: 1728 Location: Fleetwood, Pa | John, I need all the passenger side trim moldings for a 58 Desoto Firesweep 4 door hardtop. Can you help me out? | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | sidesho_bob1961 - 2018-10-24 7:47 AM John, I need all the passenger side trim moldings for a 58 Desoto Firesweep 4 door hardtop. Can you help me out? Wish I could help, Bob, but both the '58 4-doors I have the trim is all missing. ---John | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | Picked up a '55 Chrysler Windsor coupe, '58 DeSoto Firedome sedan, and a couple '57 Plymouth sedans for parts. Please PM me for needs. ---John | ||
floyd066 |
Extreme Veteran Posts: 347 Location: Ocean Park, Washington | Hey John, might you have a good set of bumpers for a 56 Windsor? Not holding my breath. | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | floyd066 - 2019-01-03 9:01 PM Hey John, might you have a good set of bumpers for a 56 Windsor? Not holding my breath. Looks like I have a decent front bumper with good chrome, but not a rear one. ---John | ||
floyd066 |
Extreme Veteran Posts: 347 Location: Ocean Park, Washington | Could you shoot me a pm with some pics? | ||
gradford |
Regular Posts: 87 | HI John, It's Glenn from Victoria, BC. I'm looking for a decent steering wheel for a 56 Plymouth; either the standard wheel or the Hollywood style wheel. Do you have one? | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | gradford - 2019-01-10 12:18 AM HI John, It's Glenn from Victoria, BC. I'm looking for a decent steering wheel for a 56 Plymouth; either the standard wheel or the Hollywood style wheel. Do you have one? Hi Glenn, I checked, but had no luck with a decent steering wheel. ---John | ||
westaus29 |
Veteran Posts: 147 Location: Mandurah, Western Australia | Hi John Any chance you have a pair of Belvedere script badges in reasonable condition for front guards of 55 Plymouth? The rest of my chrome is a bit tired, matches the rest of the car, so dont need extra good ones Jim | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | westaus29 - 2019-01-11 4:54 PM Hi John Any chance you have a pair of Belvedere script badges in reasonable condition for front guards of 55 Plymouth? The rest of my chrome is a bit tired, matches the rest of the car, so dont need extra good ones Jim I haver a pair of these, but both are in pretty nice shape, not perfect though. If these are of interest, please PM me. ---John | ||
ply57nz |
Regular Posts: 94 Location: New Zealand | Hi John, Do you have a clamp for the steering column jacket on a 57 powersteering box, I think they use 2 bolts to clamp the jacket, also after the parts that fit under the steering wheel that make the horn work with the PS unit. Still after a cap for the PS pump if you have had anything show up lately. Cheers Norm | ||
big m |
Expert 5K+ Posts: 7805 Location: Williams California | ply57nz - 2019-03-21 8:22 PM Hi John, Do you have a clamp for the steering column jacket on a 57 powersteering box, I think they use 2 bolts to clamp the jacket, also after the parts that fit under the steering wheel that make the horn work with the PS unit. Still after a cap for the PS pump if you have had anything show up lately. Cheers Norm I should be able to come up with those parts, Norm. Except for the P/S pump cap, that is. ---John | ||
ply57nz |
Regular Posts: 94 Location: New Zealand | Great thanks for that John, just let me know how much. If you have a 57 P/S pump show up let me know, probably would'nt hurt to have a spare. Could also do with the clip that holds the lock in the trunk lid if you have one Cheers Norm Edited by ply57nz 2019-03-23 8:40 PM | ||
