Help an idiot with his brake drum outer spring Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 9899 Location: Lower Mainland BC | The other day, I decided to paint a rear brake drum on my 56 Dodge. As I did so, I rolled the external vibration damper spring(s) out of the grove in which they sit. I only intended to roll the spring(s) out about 1/2" or so - just enough to paint the grove. HOWEVER I don't know what I did, when I let go of the spring, it rolled completely off the drum and separated. So far I have made one feeble attempt at getting the spring back on. The factory must have used a spreader of some type to get them on. Whatever, I need some hints as to how other people have fixed this issue and got their spring(s) back on the drum. Edited by 56D500boy 2016-10-18 1:54 AM | ||
mstrug |
Expert 5K+ Posts: 6498 Location: Newark, Texas (Fort Worth) | It would seem that the spring would disconnect at the ends. wrap around drum and reconnect with a brake spring tool or 2 vice grip pliers. http://www.ebay.com/itm/58-Plymouth-brake-drum-spring-/111975080658... | ||
Expert 5K+ Posts: 9899 Location: Lower Mainland BC | Yes, the two ends of the spring do have catches/loops/hooks that were joined together. The "problem" is the distance between the ends of the springs when you wrap it around the drum is about 4 to 5 inches. I don't know how to "pin" one end and then pull the other end over with vice grips and hook them together. I tried to hook them together and then roll the loop back on to the drum but I need to stretch it the same 4 to 5 inches first to get that going. In my mind I see a tapered cone but I it would have to be made of thick steel. There is probably a tool to do this. I just don't know what it is or looks like. (I don't think a normal brake spring tool will work due to the distance involved). Edited by 56D500boy 2016-10-17 9:50 PM | ||
mstrug |
Expert 5K+ Posts: 6498 Location: Newark, Texas (Fort Worth) | If you ran a piece of strong wire .041" stainless steel should do it, inside the spring both ways, twist it a couple coils in on each side, pull and connect. | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | roll the spring on work at 180* from the joing ends . the trick is to roll both spring ends equally . always worked for me in years before recorded history ----------------------------------------------later | ||
51coronet |
Extreme Veteran Posts: 360 | I just muscled them together on the drum.....yeah not everyone can do that (wear gloves to avoid the pinch). I have seen people use 2 screwdrivers and carefully get them together. Rolling them onto the drum while connected carefully is another method. Some tools are available http://www.sears.com/craftsman-brake-spring-pliers/p-00945494000P?s... Brake drum spring pliers | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | 60 dart - 2016-10-18 5:48 AM roll the spring on work at 180* from the joing ends . the trick is to roll both spring ends equally . always worked for me in years before recorded history ----------------------------------------------later I second that - this is the easiest way.. | ||
