Dodge Kingsway 59
Moderators: wizard, Windsor59
   Forward Look Local Regions -> Scandinavian RegionMessage format
bshopov
Posted 2016-10-11 4:22 AM (#523160)
Subject: Dodge Kingsway 59
Hej alla,
Jag bor i Bulgarien och har Dodge Kings 59, skulle jag vara glad om någon hjälpa mig med information om delar i ditt område. Viktigast lister på dörrarna och fendrar av bilen. Om någon har information om var jag kan hitta sådana remsor Jag ska vara glad om du sa också ute efter några delar för denna modell.
Vänligen om du har information om Dodge Kings 59 delar i ditt område - dela min
tack
Posted 2016-10-11 6:33 AM (#523166 - in reply to #523160)
Subject: Re: Dodge Kingsway 59
500050002000100025
I write in English for the conveinancy for our Finnish members.
You have turned to the right market for the Kingsways - in the old Days they were common here, but now we don't see them very often.
I know of only one '59 that has been stored since the seventies, but unfortunately not for sale and not a parts car.
I do believe that they were common also in FinLand.
You could try to post an add on the "Blocket" https://www.blocket.se/ or on http://www.usabil.nu/databas/delarkopesdefault.asp
Perhaps we get some feedback also from FinLand
spinout
Posted 2016-10-11 11:23 AM (#523180 - in reply to #523166)
5001001001002525
I understand, wizzz, what he writes (without translator). It depends on whether the car is a base Kingsway, a Kingsway DeLuxe or a Kingsway Custom. I believe
a base '59 Kingsway had same side and fin moldings as '59 Plymouth Savoy, and Kingsway DeLuxe had same as in Plymouth Belvedere, and Kingsway Custom
had same as in Plymouth Fury. Most other parts were interchangeable with Plymouth, so look for Plymouth parts too since they are more common..
bshopov
Posted 2016-10-11 2:06 PM (#523192 - in reply to #523180)
Please tell me are headlights from Plymouth 59 compatible with headlight of Dodge Kingsway 59
Thank you
Posted 2016-10-11 2:41 PM (#523201 - in reply to #523160)
500050002000100025
Please clarify - do you mean the seald beam headlights (if so, yes) or do you mean the garnish around the headlamps (if so, no)
bshopov
Posted 2016-10-11 3:05 PM (#523207 - in reply to #523201)
I mean only beam headlights not garnish around them. O.k So I can buy these headlights and put on my Kingsway 59
Thank you
By the way my Kingsway 59 is Custom, because has fury 59 trim package
Posted 2016-10-11 3:39 PM (#523208 - in reply to #523160)
500050002000100025
Those are common look for 4000 and 4001
bshopov
Posted 2016-10-11 4:39 PM (#523213 - in reply to #523208)
what does mean 4000 and 4001?
Posted 2016-10-11 4:47 PM (#523214 - in reply to #523160)
500050002000100025
As an example http://www.ebay.com/itm/NOS-Mopar-GM-FORD-1970s-GE-Sealed-Beams-/22...
There are also "yellow" ones (made in X asian country) which are "cheaper" in all thinkable ways
bshopov
Posted 2016-10-12 3:25 PM (#523303 - in reply to #523214)
Thank you for all information
Adventurer 60
Posted 2016-10-14 3:08 AM (#523404 - in reply to #523166)
50010010010025
wizard - 2016-10-11 6:33 AM
Varför? nästan alla finnarna har läsat svenska i skolan. Vi behöver practise man
Swenglish är also mycket allowed
