brief instructions to remove a torqueflight from hemi
Posted 2016-09-24 10:51 PM (#522048)
Subject: brief instructions to remove a torqueflight from hemi
5000
Okay I havent gotten under the car yet.
Remove parking brake cable? its connected to the body(crimped under the dash i saw).  Pull the drum off? Is there  a bolt on the drum or driveshaft bolts hold it on?
Speedo cable? How to
Shift cable how to?  bolt and screwdriver and pop clip i saw?
Posted 2016-09-25 3:11 PM (#522086 - in reply to #522048)
Subject: RE: brief instructions to remove a torqueflight from hemi
20001000500100100252525
Download yourself a service manual.
http://www.mymopar.com/index.php?pid=109
ttotired
Posted 2016-09-25 6:29 PM (#522099 - in reply to #522048)
Subject: Re: brief instructions to remove a torqueflight from hemi
50002000100010010010010025
Yep, read and understand manual, undo bolts, remove transmission
Side note: these transmissions weigh as much as a modern engine, dont try to be a "HE Man" and drop it on your chest or you will have broken ribs (at best)
