Location: 33844 | Has anyone found a cheap , generic replacement for our power window motors ?? Any DC motor with 2-3/4 body and 5/16 shaft would work , me thinks !! |
Location: 33844 | Bingo -- found it on ebay. Good fit , just need to grind the D on the shaft , and only $18 total !!! |
Location: Victoria, BC, on Vancouver Island, Canada | What kind of a motor was it? |
Location: 33844 | search 12v dc motor on ebay --- sold by stuff4boats. I think it is a winch motor !! |
This one?
http://www.ebay.com/itm/12v-DC-motors-/172145763007?hash=item2814af... |
Location: 33844 | The shaft is even the right length. It has teeth , but I just run it with 12v and hold against grinder to turn it down to 5/16 , then grind a flat side. And a couple layers of duct-tape to snug it in the mount. |
Location: 33844 | Whoa --- do our power-window motors reverse the usual way -- by reversing the polarity to the leads ??? Or do they use chassis ground and apply 12V to one lead or the other !!! |
Location: Ottawa, ON | I my 61 they are reveresed by using the chassis ground and applying 12V to on lead or the other. |
Location: Southern Sweden - Sturkö island | Polara61_383 - 2016-08-08 11:07 AM
I can confirm the above also for '59 and '60 as well as later models.
So, did anyone mount them yet and if so, did the rpm/torque work in a simular way as the original motors?
Does the bolts for the reduction gear correspond to the motor? |
Location: 33844 | So our FL window motors are special that way. Most DC motors reverse simply by reversing the leads !!! I guess Ma Chrysler did this to simplify the wiring somehow ??? |
