58 Plymouth convertible weatherstrip
antonellomopar
Posted 2016-07-15 10:51 AM (#516756)
Subject: 58 Plymouth convertible weatherstrip
100100100252525
Hello
is there any source for some convertible top weatherstrip? Need the header panel and side rails w/s. Any idea?
FIN_NV
Posted 2016-07-15 5:49 PM (#516784 - in reply to #516756)
Subject: Re: 58 Plymouth convertible weatherstrip
20002000500252525
Gary Goes should have what you need.
antonellomopar
Posted 2017-12-06 5:18 PM (#553819 - in reply to #516756)
100100100252525
still looking for these parts. Had sent a letter with a check to Goers one year ago, with a list of few parts I was needing, but no reply on anything, no parts either. Also, looking for door panels for the same car. Don't want to deal with SMS once more, after waiting interior matherial for the car for over a year. I haerd someone in Sweden..any help?
miquelonbrad
Posted 2017-12-08 8:22 AM (#553904 - in reply to #516756)
100050010010025
Gary Goers is not in good health, and is closing down his business. As for SMS, I believe that they are the only ones doing any of the interior cloths and embossed vinyl materials. If you have the cloth and vinyl, you can probably find a local upholstery shop to manufacture the door panels.
antonellomopar
Posted 2017-12-09 3:33 PM (#553990 - in reply to #516756)
100100100252525
Brad, , I already have sourced all interior stuff from SMS, and have just ordered the door panels from them. I know wait will be longer than anticipated, but have old stuff that can work for the moment. They quoted 775 $ for the interior panels, which is not crazy. Thay told me late january, but am pretty sure they will be delayed. Found some roof rail w/s from Bernbaum, but have no idea if they fit correctly or if they are wrong. Any feedback on them?
antonellomopar
Posted 2018-01-14 8:25 AM (#556197 - in reply to #516756)
100100100252525
Got the top frame weatherstrip, and while profile is accurate, nothing else is correct. Holes are spaced wrong and lenght of rubber pieces is wrong. Original w/s on car are six pieces, while Bernbaum stuff is 8 pieces. Four are about the correct length, the front and rear pieces can be cut to fit. But the other four pieces are too short to be used, unless they are glued together. Really don't understand why they couldn't be cut correctly. What is the sense and the reason of getting a fairly correct profile...but wrong length and wrong hole spacing.
