putting a modern 383 into my 57 plymouth suburban
   Forward Look Announcements -> Frequently Asked QuestionsMessage format
57 suburbia
Posted 2016-07-07 10:08 PM (#516188)
Subject: putting a modern 383 into my 57 plymouth suburban
any suggestions on engine mounts ? trying to get by as cheaply as i can i also have a 65 727 to go behind it. so far other than ordering some custom mounts i cant find any, some say there are some truck big block mount that will almost bolt in? any help thanks guys and gals
Posted 2016-07-08 5:08 AM (#516201 - in reply to #516188)
Subject: Re: putting a modern 383 into my 57 plymouth suburban
50001000100100100100252525
There isn't a cheap way to do this unless you can weld all your brackets. Here is a spool setup and you will need frame standards too.
http://www.classicindustries.com/product/mopar/parts/mn1935.html
http://www.classicindustries.com/shop/mopar/parts/engine/engine-mou...
http://www.tdperformance.com/Engine-Swap-Motor-Mount-Kits
http://www.parts-vehicle.com/detail/parts/FAIRCHILD-RANGER-6-440-EN...
57plybel
Posted 2016-07-09 2:46 AM (#516285 - in reply to #516188)
Subject: RE: putting a modern 383 into my 57 plymouth suburban
500252525
What config is it at present 57 suburbia?   6 0r 8 cyl ?
Colin
Posted 2016-07-09 5:22 AM (#516290 - in reply to #516188)
Here is what the original mounts look like:
http://internationalchristineclub.net/showthread.php?2375-Marcs-195...
Edited by mstrug 2016-07-09 5:27 AM
57 suburbia
Posted 2017-01-07 12:20 PM (#530697 - in reply to #516285)
Sorry so late and thanks for the hep it has the 301 2 spd auto
58coupe
Posted 2017-01-07 9:22 PM (#530752 - in reply to #516188)
100050010010025
The factory spool mounts are a little hard to find but your Plymouth frame already has the correct brackets to use these. What you need are the engine spool mounts from a 58 or 59 Plymouth, Dodge, Desoto, or 59 Chrysler that had a big block. These will bolt up to your newer 383 and also fit your frame.
You could also possibly modify your 301 mounts to fit the 383 engine. the bolt pattern is slightly different on the ears of the poly versus big block.
Edited by 58coupe 2017-01-07 9:25 PM
wayfarer
Posted 2017-01-08 12:26 PM (#530802 - in reply to #530752)
500100100100252525
You might check with www.wildcatmopars.com or www.bigmauto.com for the oem mounts.
As 58coupe notes, the 301 mounts can be modified, which I would look at real hard.
