Location: Southern California | anybody know which engines I can rebuild to bolt up to my fresh rebuilt A488 trans? long story but my motor rebuild RB 383 took a crap and need a new motor .
thanks |
Location: Southern California | anybody have a solid RB 383 block and heads? (no cracks) |
Location: Southern California | not B 383 need 1960 1 year only RB383 |
Any pre-'62 big block would be a bolt-in for your existing setup. If your crankshaft is good you could swap it into a 413, 426 or 440. |
Location: Peoples Republic of Oregon | Not many folks will actually look at the stamped code to see what you have and few will be able to look at installed engine and see that it is a 413 or 440 block.
If you are in the mood for subterfuge then machine the pad and re-stamp it....... |
