Burnt main power wire Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | This is from my 60 dodge phoenix and was an old burn that someone left in. How this car never burnt to the ground is amazing. Now this repair, even though it was on my dodge, is not specific to my car (mostly), it is basically the same repair as to any mopar (in particular) up to the early 70s (I think) when they finally got around to fitting FUSEABLE LINKS to the main power feeds for the cars (and trucks, this happens to them as well) There are a couple of white plugs looped together in my pictures, that can be disregarded as I made it so that I can have either the brake lights or the reverse lights work as the rear flashers by swapping from one plug to the other Anyway heres all the pictures and I know I harp on about it, but put fuseable links (or whatever heavy fuse you like) into your wiring to save having to do this job (Dash removal (48)s.JPG) (Wiring 001s.JPG) (Wiring 002s.JPG) (Wiring 003s.JPG) (Wiring 004s.JPG) (Wiring 005s.JPG) (Wiring 006s.JPG) (Wiring 007s.JPG) (Wiring 008s.JPG) (Wiring 009s.JPG) (Wiring 010s.JPG) (Wiring 011s.JPG) (Wiring 12s.JPG) Attachments ---------------- Dash removal (48)s.JPG (129KB - 180 downloads) Wiring 001s.JPG (95KB - 174 downloads) Wiring 002s.JPG (87KB - 170 downloads) Wiring 003s.JPG (101KB - 168 downloads) Wiring 004s.JPG (95KB - 186 downloads) Wiring 005s.JPG (87KB - 187 downloads) Wiring 006s.JPG (96KB - 196 downloads) Wiring 007s.JPG (73KB - 181 downloads) Wiring 008s.JPG (110KB - 172 downloads) Wiring 009s.JPG (75KB - 182 downloads) Wiring 010s.JPG (108KB - 182 downloads) Wiring 011s.JPG (93KB - 196 downloads) Wiring 12s.JPG (94KB - 181 downloads) | ||
NicksGarage |
Expert Posts: 1223 Location: Ramona, CA | Where do you suggest putting in fuses or fusible links? I have some sort of short in my 300F in the lighting that causes the starter to keep cranking when I let off on the ignition switch. Have replace the switch twice. A previous owner had the cluster redone by JC auto but it smoked the gas gauge when he put it back in. Don't know if it's related to that but I now they bypassed the voltage limiter in the oil gauge and put a separate one in somewhere. I'll have the car out this weekend to try and track it down. It had mice in it when it was stored in a barn and I did find some chewed wires under the hood that I fixed already. I have a feeling I'm going to need to pull the dash to really track it down. | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | In the picture thats been washed out by the flash, you can see the fuseable links that I fitted, the last picture you can see it up the top where the red wire goes into a white plug and comes out yellow. There are a few wires in there without ends that are 2 colour wires (EG blue and white), these are extra wires that I incorporated into the harness while it was apart for future "extras" such as A/C (which it now has) so I didnt have to string more wires around. Main thing is space, you need to be able to lay it all out once you have removed it from the car, so as you strip the old tape off you can rebind the harness together as you go, paying particular attention to the branches. If you try to rush this bit, you are going to end up with a huge jumble of wires and almost no hope of ever fixing it While your stripping, do not try and remove any burnt wiring, get all the tape off first so you can see what you have got to work with. Once the tape is off, you should be able to see exactly where the burnt wire went and where it stopped, now you can start removing it. Start from one end and start peeling it out. You need to be slow and careful doing this, the burnt wire will have melted itself into other wires and also will be a bit interlaced with other wires, so you will need to untangle it a bit as well. You are looking for where the main burnt wire has melted into others, if there is a melt through (bare copper), you will need to repair this secondary damage as well, so note it down somewhere so you dont forget. As your peeling the wire out, you will come across places that you have bound the harness, you have to undo this, pull the burnt wire out and rebind it. You might think that as your pulling the old wire out, that you could put the new one in, not a good idea, as you will mess your branches up dealing with 2 wires at once, so just go along peeling and checking until you get the burnt wire out. If the wire has a factory join to make a branch, closely inspect that branch and if no evidence of melting is there, you can cut that join to leave that branch wire in, and reconnect it as your laying in the new wire. Once you have your crispy one out, go back and fix all the secondary damage, in most cases, it will be relatively minor and will only require a small wrap of tape. If the secondary burn damaged the copper or caused another melt, then more severe repair will be required including whether you need to replace that wire as well. Once thats all done, you can replace your main burnt power feed, again, take your time, follow the harness along and be sure not to short cut the corners and remember to only undo one bind at a time as you go along and you will get there. Once you have the harness all back together (are you sure, you didnt miss anything, best to have another look and be sure) you can start retapeing. Leave your bindings on, just tape over them (factory did this as well). I start with the branches first, tape from the main stem of the harness and work your way to the end, then start at one end and tape it all through. There is a technique to taping, first, not to tight, if you tape it to tight, it wont be flexible and will be painful to refit. Second is how to tape, you basically want to have 1/2 the width of the tape over lap 1/2 the width of the tape as you go along. This gives you 2 layers of tape over the wires, this takes time to do, but will look very neat when done. In my pictures above, you will see I laid out the entire harness and hooked up a lot of the components, You do not have to do this, it was more me playing around with my blinker modification and testing stuff I will say that wherever possible, remove your switches and stuff and reconnect them to the harness, this takes extra time, but saves bulk time when your putting it back and wondering where "THAT" wire went, also, plenty of pictures and label as much as you can This will take the average person somewhere between 2 to 3 full weekends to do, it wont be that expensive for the parts you will need (providing it hasnt smoked a switch or something), but it will be expensive in time, it will also be very uncomfortable, awkward, you will loose skin and blood, you will swear a lot and curse the stupid engineer that thought that this was a good place to put that, but it will be memorable and you will learn a lot about your car. If you pay someone to do this, take into account that there is a lot of hours work to do this (somewhere around a day, just to get the wiring out), so, paying by the hour, it will add up, its NOT just a wire, its a repair/rebuild of the nervous system of the car, it must be done right or it will fail I hope this helps anyone having a go at doing this or at least gives you an idea whats involved and I will say it again, FIT FUSES TO YOUR CAR, THIS WILL HAPPEN IF YOU DONT, ITS A MATTER OF TIME | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Nick, the fuses go just near the battery, you should see fat red wires there somewhere They maybe on a start relay/solenoid (normal spot on our era mopar, but around the battery on later ones) Now the purists or guys that are into shows that pick on paint markings are not going to want to fuse there cars as it will be "Incorrect", but it can still be done by making the fuses use a junction block or even (I hate these ugly things) a megafuse that can be easily undone at "show" time and hooked back as per standard. | ||
