Waterless Engine Coolant Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
NicksGarage |
Expert Posts: 1223 Location: Ramona, CA | The cooling system on my 300F seems to be in good shape except that the lower tank seam on the radiator has a leak. The coolant is nice and clean and the car runs cool. When I have the radiator out to be repaired, I'm considering changing to waterless engine coolant. http://www.evanscooling.com/ This stuff is supposed to work better than standard coolant. No corrosion problems or boiling over and is a lifetime product. All positives for a car that is not used all the time. Of course it is an expensive change over as you have to flush out the existing system when you do it. Has anyone else here used it? Thanks, Nick. | ||
Board Moderator & Exner Expert 10K+ Posts: 13042 Location: Southern Sweden - Sturkö island | I have thought about it Nick, it works well, lt that's what I hear. The cleansing process is costly, as the coolant. One must absolutely make sure that the heater core, radiator, Engine block and freeze plugs as well as hoses are in excellent shape..... In my case, I'm not sure about the state of my heater core, and freeze plugs.... | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | at over 50$ a gallon , it oought to change itself -------------------------------------------later | ||
ronbo97 |
Expert Posts: 4034 Location: Connecticut | So what happens when you're at a club meet many miles from home and you discover that your cooling system has a leak ? Can you add water ? Or let's say that you need a gallon of this stuff five years from now and you discover that the company is out of business ? Ron | ||
NicksGarage |
Expert Posts: 1223 Location: Ramona, CA | ronbo97 - 2016-05-12 4:11 PM So what happens when you're at a club meet many miles from home and you discover that your cooling system has a leak ? Can you add water ? Or let's say that you need a gallon of this stuff five years from now and you discover that the company is out of business ? Ron They say you can add water to it but then you'll need to replace it later. Some forums say that you can heat up the coolant in a big pot and boil off the water and then reuse it. Also, they seem to have been around for a long time. I guess all these things are risks and it's not cheap but I'm not looking to do the cheapest things on a car that cost me a lot of money. | ||
Board Moderator & Exner Expert 10K+ Posts: 13042 Location: Southern Sweden - Sturkö island | Then there's the back to basic routine guys; I have "solved" many overheating issues on cars by flushing out the cooling system (sometimes using a cooling system flush) and filling up the cooling system with distilled water and ethylene glycol in a 50/50% mixture. Also, checking the radiator cap and the function of the thermostat. In the old days, it was recommended to use rain water for the cooling systems due to that there is no calcium in it. Since then, this knowledge has been forgotten and many use normal tap water with calcium that will create an isulating coating inside the engine block and the radiator. Ron has a point and that's one of the reasons why I didn't use the waterless cooling fluid - clearly, the price is another.... | ||
57desoto |
Expert Posts: 1488 Location: New Castle PA | If you just want to give your coolant a "boost", I suggest "Purple Ice". It can be added to "normal" coolant and helps immensely. I use it in my Adventurer. | ||
Board Moderator & Exner Expert 10K+ Posts: 13042 Location: Southern Sweden - Sturkö island | Cool Ed I read up on the Purple ice - practically it's a water wettener, changing the surface tension of the water. This could be a help for those who runs a Little hot even though the system has been cleaned and flushed and filled up with correct water/glycol mixture. Thank's for sharing! | ||
sconut1 |
Elite Veteran Posts: 782 Location: Edmonton, Alberta | I've never used the Evans stuff myself. I spoke with a fellow at a show here who switched to it and had "overheating" issues. Not with the coolant boiling over, I think the Evans stuff has a very high boiling point... his comment was that the car was running hotter on the gauge that it used to. He switched back to Glycol and hasn't had issues. His story as told to me. Myself, just as an opinion, I personally think that the Evans product is a solution in search of a problem. For what its worth, I've heard very good things about purple ice myself. As Wizard said, if you tend to run a little warm, it would probably be very beneficial to use. | ||
Chopper John |
Expert Posts: 1488 Location: Florida | Jay Leno's Garage videos on the subject: https://www.youtube.com/watch?v=t7PykrgzWPQ https://www.youtube.com/watch?v=KRLXKW2ph0w | ||
51coronet |
Extreme Veteran Posts: 360 | Expensive for what it does. Modern coolants do a great job of stopping corrosion when used with distilled water. The boiling point is pretty high with modern coolants as well. I would only consider Evans with a completely leak tested proven system. I pulled out my heater core and that thing has so many tiny pin hole leaks everywhere its insane. I would not recommend spending the money on this coolant unless the hoses are replaced, and the system is leak tested beyond 16 psi just to be sure. | ||
Mopar1 |
Expert Posts: 3027 Location: N.W. Fla. | wizard - 2016-05-13 12:49 AM Distilled water for the same reasons....In the old days, it was recommended to use rain water for the cooling systems due to that there is no calcium in it. Since then, this knowledge has been forgotten and many use normal tap water with calcium that will create an isulating coating inside the engine block and the radiator. .... | ||
