NEED CHOCK KIT FOR 2/4 BBLS------ FROM EXHAUST MANIFOLD
Ron
Posted 2016-04-21 2:03 PM (#509913)
Subject: NEED CHOCK KIT FOR 2/4 BBLS------ FROM EXHAUST MANIFOLD
NEED CHOCK KIT FOR 2/4 BBLS------ FROM EXHAUST MANIFOLD TO BACK CARBURETOR. I HAVE THE FITTING IN THE EXHAUST MANIFOLD. ENGINE AND STOCK 58 CHRYSLER 300-D FACTORY SETUP. I THINK IT IS THE SAME FROM 55 TO 58 SINCE CARBS ARE WCFB TYPE.
ANY INFORMATION WILL HELP. THANKS
RON SWARTLEY
E MAIL ARCHANGEL1390@AOL.COM
PHONE 717-939-3429
Posted 2016-04-21 3:07 PM (#509918 - in reply to #509913)
Subject: Re: NEED CHOCK KIT FOR 2/4 BBLS------ FROM EXHAUST MANIFOLD
50001000100100100100252525
Choke kit?
grunau
Posted 2016-04-22 8:04 AM (#509978 - in reply to #509918)
10010010010025
Hi
Have a look at this ....
http://www.ebay.com/itm/1956-61-CARTER-WCFB-CHOKE-ASSEMBLY-DUAL-QUA...
and these guys should have something....
http://www.carburetor-parts.com/WCFB_c_139.html
http://carbkitsource.com/
http://www.thecarburetorshop.com/CarterFourBarrelCarburetors.htm
Posted 2016-04-22 3:01 PM (#510007 - in reply to #509978)
20001000500100100252525
I suspect the OP is looking for the sleeved heat tube that leads from the exhaust manifold to the choke housing.
Posted 2016-04-23 10:22 PM (#510093 - in reply to #509918)
5000500050005000200050025
I make my own chocks to match the originals. Basically a 4x4 cut at a 45ยบ angle
with beveled edges. As far as I know, these were not special to any type of carburation.
firedome
Posted 2016-04-29 10:41 AM (#510474 - in reply to #510093)
200010001002525
LOL... I have an original chock left from my '58 Sweep, originals are the best for optimum performance and mpg!
