1960 Torqueflite problem
OzFury
Posted 2016-04-14 3:06 AM (#509358)
Subject: 1960 Torqueflite problem
1002525
Hi Guy's
I have dropped my trans off at the shop to be repaired.
After removing it we discovered the drive sleeve was not engaged in the pump BUT was engaged in the converter
& as a result has ground away the front pump drive lugs on the pump & damaged the pump drive sleeve. So far that is all
he has found until he pulls it down fingers crossed that is all the bad news.
Anyway my question is were can I source a front pump & drive sleeve from ?
(016 (Medium).JPG)
Attachments 016 (Medium).JPG (75KB - 198 downloads)
