Location: McComb, Mississippi | My 63 imperial has a sway bar setup on the rear axle. I cannot find a source for bushings. Can someone point me in the right direction? Thanks |
http://www.p-s-t.com/
http://energysuspension.com/products/Sway-Bar-End-Link-Bushings.htm... |
Location: Peoples Republic of Oregon | Maybe a photo will be helpful.
More than a couple of different bushings have been used over the years and something might be a good interchange. |
Location: Newark, Texas (Fort Worth) | http://www.moparmall.com/SearchResults.asp?Search=sway&Submit=
http://www.ebay.com/sch/Sway-Bars-/33592/i.html?MModel=Imperial&MMa...
Edited by mstrug 2016-03-16 8:57 PM
You wrote ... "a sway bar setup on the rear axle". The 1963 MoPar Parts Book used by every one of the four Divisions does not show a Rear Sway Bar in Section 17.
Rodger & Gabby
COS |
Location: North Australia | Hey Morg, you might be asking about your Imperial rear strut rod bushings, not sway bar?
steve. |
Location: McComb, Mississippi | Yes , forgive me. I meant strut rod bushings. |
Location: North Australia | This might be what you need?
http://www.ebay.com/itm/Rear-Axle-Control-Strut-Bushings-for-1956-1... |
In later years --- The CSS-HHP Dodge Pick-Ups ( The ones with a Stripe and The Raised Big Block ) got to use the same item which was un-changed from
The Imperial Division.
Because of this --- go to your local NAPA. It was an Only Imperial Division Part from 1957 to the end of the 1966. The Dodge "half Ton" that used this was
only during the CSS-HPP years.
Rodger & Gabby
COS
The lumping of The Imperial Division and The Chrysler Division by NAPA may have this listed first as a Crashler Part in their system
