need new radiator for 60 windsor
bad58mike
Posted 2016-03-06 4:44 PM (#506008)
Subject: need new radiator for 60 windsor
10001002525
looking for a new radiator for a 1960 Chrysler Windsor. Any leads to one you've found that works for our cars? Jegs? summit? or elsewhere?
thanks
jimntempe
Posted 2016-03-06 9:09 PM (#506033 - in reply to #506008)
Subject: Re: need new radiator for 60 windsor
2000100100100
If you find one please come back and post what you found. I've been trying to collect leads on what fits. I hung onto this pic from ebay as it looked like a possible interchange.
(cu showing part number.jpg)
(New 3 Row All Aluminum Radiator 1968 1974 Dodge Mopar Cars 22_ Core Big Block _ eBay.jpg)
Attachments cu showing part number.jpg (155KB - 164 downloads)
Attachments New 3 Row All Aluminum Radiator 1968 1974 Dodge Mopar Cars 22_ Core Big Block _ eBay.jpg (118KB - 168 downloads)
Polara61_383
Posted 2016-03-07 6:24 AM (#506045 - in reply to #506008)
1002525
I ran this one for about a year, it worked well and I only had to trim the side rails a little to make it fit my 61 Dodge: http://www.ebay.com/itm/2-Row-1963-1967-MOPAR-22-Wide-Core-Champion...
I replaced it because of the non-OEM appearance.
bad58mike
Posted 2016-03-07 12:57 PM (#506071 - in reply to #506008)
Subject: RE: need new radiator for 60 windsor
10001002525
thanks for the leads. Found a great place near by to build me one
Mattsons custom Radiator in Stanton Ca
jimntempe
Posted 2016-03-07 9:15 PM (#506097 - in reply to #506008)
2000100100100
Is the stock radiator on these 1.5 inch hose diameter on the radiator side? I seem to recall one of the hose diameters is 1.75. is that on the water pump inlet/suction port?
Polara61_383
Posted 2016-03-08 4:36 AM (#506119 - in reply to #506008)
1002525
The upper hose going to the thermostat housing is 1.5", the lower one going to the pump (suction port) is 1.75".
