Rad. pics
Moderators: big m
   Forward Look Local Regions -> Pacific Northwest RegionMessage format
59 in Calif
Posted 2015-12-31 12:20 PM (#499571)
Subject: Rad. pics
Hey Guys, maybe a pic might be more helpful. The rad cap sets 2 1/8" higher than rad support. I can't lower the rad as it sets about 1/2" above the crossmember. I just spent $400 getting a 3 row core put in it. I had this rad laying around, don't know what it came out of. Going to really *iss me off if I have to have that rad guy shorten that rad 2". Thanks, Jerry
(Rad 001.jpg)
(Rad 002.jpg)
Attachments Rad 001.jpg (113KB - 335 downloads)
Attachments Rad 002.jpg (95KB - 286 downloads)
60 dart
Posted 2015-12-31 7:44 PM (#499610 - in reply to #499571)
Subject: Re: Rad. pics
50002000100050010010010010025
set your hood in place and check it . you got the latch close , you got the firewall in back . should tell ya in a heart beat . i thought mine might hit with a new aluminum rad . it
does push up the hood insulation just a bit but so did my old air cleaner , til i changed it to ------------------------------------------later
58coupe
Posted 2015-12-31 9:00 PM (#499617 - in reply to #499571)
100050010010025
It's a Mopar rad. should be a number on top. That should tell you what it fits.
59 in Calif
Posted 2016-01-01 2:16 PM (#499661 - in reply to #499571)
I temporarily set the hood in place and the rad keeps the hood latch too far up from engaging. Thinking i will get the front clip on and recheck that clearance then. Jerry
60 dart
Posted 2016-01-01 6:48 PM (#499684 - in reply to #499571)
what does the core height measure . if i remember , it should be @ 17 1/2" , total to the top of cap @ 23 3/4" -----------------------------------------------later
also whats the part number on the top of the tank -----------------------------------later
Edited by 60 dart 2016-01-01 6:51 PM
59 in Calif
Posted 2016-01-02 12:19 AM (#499714 - in reply to #499571)
If I remember correctly it is 22". The wrong rad that was there is 20" but the top tank was also shorter and not a Chry rad. Was hoping to install a period correct rad. The width is correct for opening in the support. I'l take a look at that P/N tomorrow. Jerry
