Location: San Antonio TX | So I just lost my starter on my 61 Windsor, and nobody in town sells a direct replacement. It's a 383.
Where should I look for a new one? Right now, I'm looking at either having a guy in town rebuild it, or buying an after market from Summit/Jegs.
Any suggestions? I'd prefer new/remanufactured/rebuilt over used. |
Location: Arizona | I'd get it rebuilt locally if the shop has a decent reputation. |
Location: San Antonio TX | jimntempe - 2015-11-15 7:45 PM
He does. I'd just rather find a direct ready-to-go replacement as they're usually a bit cheaper. Usually. |
From my experience, parts store starters are rebuilt in a factory environment and the customer becomes the tester. A good local shop will spend more time and give the part individual attention, that's why they cost more. |
Location: BELTSVILLE, MARYLAND 20705 | HAVE THE STARTER REBUILT, IT FITS YOUR CAR .... I HAVE NEW REBUILDS IF YOU NEED ONE |
Location: Michigan | If you want a direct copy then that will be potentially hard. if you want a modern replacement, then Summit Racing, Hot Heads & Powermaster sell the best small but high torque starters. |
Location: WHEELING,WV.>>>HOME OF WWVA | go with the newer 383 rebuild from rock auto and wire in a starter relay from epay . pretty simple to do , did it on my dart ---------------------------------------later |
Location: Arizona | Didn't your dart originally use a starter relay? |
Location: WHEELING,WV.>>>HOME OF WWVA | no , starter solenoid . now with a 69 setup the solenoid is on the starter and starter relay added to the inner fender -------------------------------------------later |
Location: Minor Hill, TN | The comments are right get it rebuilt. |
