My 1960 Fury Jump to page : 1 2 Now viewing page 2 [50 messages per page] | View previous thread :: View next thread |
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | mikes2nd - 2019-07-26 2:40 AM what? your old motor was shot? why just not get a new trans? or you grabbed a trans off a 318? No motor was good but is 65 model & the bellhousing pattern is different so a previous owner removed the locating dowels to get them to bolt together hence it doesn't line up correctly. So I have found a 60 model motor that will just need to rebuild it original trans has been rebuilt. | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Gees Graham, this really turned out bad for you. Is the engine the last bit, or more surprises turned up? | ||
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | Hi Mick, This has been the only real surprise only other problem has been sourcing bits but that's sorted & once the motor is built & swapped I'll be cruising. Although I still have to get engine parts so I shouldn't speak to soon. Cheers Gra | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | I used falcon global engine rebuild kit for the dodge for a standard kind of build. The cam I got re ground by wade cams (i think) Gary Pavolich can also supply a lot, but at more cost Depends on how you want to build it Not sure if your on it, but there is a FB page for the poly https://www.facebook.com/groups/542278482490634/ | ||
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | ttotired - 2019-07-28 6:25 PM I used falcon global engine rebuild kit for the dodge for a standard kind of build. The cam I got re ground by wade cams (i think) Gary Pavolich can also supply a lot, but at more cost Depends on how you want to build it Not sure if your on it, but there is a FB page for the poly https://www.facebook.com/groups/542278482490634/ Hey thanks for the link I joined that group now. I will do a full rebuild hope to use the heads I had done on it do you know if 1965 poly heads fit on a 1960 poly ? also need to find a intermediate shaft The 60 motor has already been oversized it has flattop pistons I have to measure it up to see if I will oversize it again or sleeve it back. | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Only differences I know of is the crank and trans mounting mounting for the later blocks, so heads should be fine | ||
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | ttotired - 2019-07-29 4:10 PM Only differences I know of is the crank and trans mounting mounting for the later blocks, so heads should be fine Cool I hope so other wise I need a set of heads as well...Which I will need later so I can use the other motor in another project Edited by OzFury 2019-07-29 1:19 AM | ||
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | Put the rear bumper on & removed the gas tank it bad in there. (66968948_10214324517174994_8328467076192665600_o.jpg) (20190729_110112 resize.jpg) Attachments ---------------- 66968948_10214324517174994_8328467076192665600_o.jpg (272KB - 180 downloads) 20190729_110112 resize.jpg (122KB - 199 downloads) | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | How much was the re chrome or were they good already? | ||
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | ttotired - 2019-07-31 9:45 AM How much was the re chrome or were they good already? Just gave em a clean & polish they were good only a few little marks | ||
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | Yoohoo new tank on it's way can't believe I found 1 here in Oz https://www.ebay.com.au/itm/CHRYSLER-MOPAR-DESOTO-IMPERIAL-LEBARON-P... | ||
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | Ok so I brought a new gas tank it has arrived | ||
