Will manual trans from 6-cyl work on 8-cyl?
professor-patrick
Posted 2015-08-02 11:39 AM (#485900)
Subject: Will manual trans from 6-cyl work on 8-cyl?
OK so I've ditched the idea of using a later model 727 trans behind the 301 in my 57 Plaza. It has the 6 cylinder (dead) with the 3-speed manual (good) now. Will this 301 bolt to the manual trans? Any idea what parts I'll need to source?
58coupe
Posted 2015-08-02 1:53 PM (#485909 - in reply to #485900)
Subject: Re: Will manual trans from 6-cyl work on 8-cyl?
100050010010025
The 57 3 speed will fit behind the 301 but it (and even the V-8 trans.) were very weak. Mopar did not use a HD 3 sp. until the BW T-85 in 1960. When I bought my first 57 Fury, it had been converted to a manual 3 sp. and I broke several of those early trans. with just a 318. Of course, I was pretty hard on them.
ram300
Posted 2015-08-03 3:58 PM (#486152 - in reply to #485900)
Subject: RE: Will manual trans from 6-cyl work on 8-cyl?
1001001002525
The V8 trans has a higher 1st gear and more robust syncros.
58coupe
Posted 2015-08-03 11:35 PM (#486220 - in reply to #485900)
100050010010025
Not sure the syncros are heavier but I used to strip the teeth off first gear and the cluster on a regular basis.
wayfarer
Posted 2015-08-04 3:49 PM (#486264 - in reply to #485900)
500100100100252525
Beyond the trans durability issues, the bell will be an issue unless it happens to be drilled for both block patterns. The flywheel is ok if the L6 is a 230.
