Sway-bar 1960
haspe
Posted 2015-01-23 5:11 PM (#468424)
Subject: Sway-bar 1960
I am looking for a sway bar assembly including strut-rods for my -60 DeSoto
oldwood
Posted 2015-01-24 2:53 AM (#468458 - in reply to #468424)
Subject: Re: Sway-bar 1960
2000500100100100100
What interchanges, yrs, makes, models???
udoittwo
Posted 2015-01-25 7:40 AM (#468545 - in reply to #468424)
Subject: RE: Sway-bar 1960
100010010010025
I've been looking for a while for a sway bar for my 60 Plymouth Suburban also. I think, a couple years ago, there was a thread on ones from other cars that might work but not sure. Hopefully, someone will jump in with a suggestion of some options? Maybe try posting under suspension and see if anyone can help.
oldwood
Posted 2015-01-25 10:19 AM (#468554 - in reply to #468545)
2000500100100100100
I know most Imperials had sway bars
62 Newport
Posted 2015-01-25 12:03 PM (#468570 - in reply to #468424)
Have you checked with Big M?
I bought a sway bar with all the parts from him.
Sportsman
Posted 2015-01-25 10:21 PM (#468612 - in reply to #468424)
1002525
This is the break down for the sway bars for '59 and '60. There were only two part numbers issued to sway bars that cover both years. I haven't check on later or earlier years, but can if anyone wants to know.
For '59 and '60 : All Plymouth, All Dodge, DeSoto Fire sweep, Chrysler Windsor used the same sway bar. 6 and 8 cylinder cars both used the same bar. Station wagon models also included in this group as well. Same part number covers both years.
For '59 and '60: "Big" DeSoto, Chrysler Saratoga and New Yorker, and Imperial used the same sway bar. Wagon models included if applicable.
The related hardware for the sway bars are pretty much the same all the way across the board, with the exception of the bushings and end cushions.
In '60 Imperial used it's own bushings and end cushions. These part numbers were also available as "Heavy Duty" options on the Saratoga and New Yorker. Presumably the DeSoto "Flites and Adventurers had this option available as well, but it's not called out specifically in the Parts Master.
In '59 The Big DeSotos, Big Chryslers, and Imperials all used the same bushings and cushions.
oldwood
Posted 2015-01-25 11:23 PM (#468615 - in reply to #468612)
2000500100100100100
can a '59-'62 Imperial bar be modified to work on a Dodge or Plymouth. I have a few Imperials from those years.
60 dart
Posted 2015-01-25 11:47 PM (#468617 - in reply to #468424)
50002000100050010010010010025
i think the imperial is too wide , both ways . i've never compared the 2 but thats my thinkin . i wish they would , as i need/want one to----------------------------------------later
