225 slant 6 what year 030-6 0226 and 6 225 T2 6 7 Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
196061SAVOY |
User has resigned from board | just wondering, iv got a 5 freeze plug 225 slant 6 with block casting numbers 030-6 and a number 0226 ,the pad under the head reads 6 225 T 2 6 7 tring to figure out what, where and when. | ||
Rodger |
Expert Posts: 1506 Location: Colo Spgs | Hola Patrick The Casting Numbers on The Block are equal to a Surname of Davis, Hernandez, O'Steen or Stalsby. Look for a machined pad on the front right of the block ( the right is the same side the Generator/ Altermator is on ). It will have a Alphabetic Stamp and at least two numbers ( aka S17 or S22 from The 1962 Plymouth Factory Service Manual ). Rodger & Gabby COS | ||
196061SAVOY |
User has resigned from board | its a strange block, raised castings on drivers side read 030-6, and then 0226, not the typical 8? number casting that u would be able to identify the block, on the pad, under the head, on the pasenger side, it reads a follows 6 225 T 2 6 7 , theres an old post on slant 6.org, where a guy has the same block, but nobody theres has an answer, could it be an industrial block,mexican made block, a factory replacement block, bus/truck/tractor/ the car its in is a 60 savoy 2 door built in los angel, cal, i know its not the correct block, i know it was mad after 67 , just trying to find out what, where and when its a puzzler, this is the block from the slant 6 club, same as mine Edited by 196061SAVOY 2014-09-26 10:45 PM (27052007124.jpg) Attachments ---------------- 27052007124.jpg (52KB - 835 downloads) | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | to add ,,, the "stamped" number should be opposite/outside of where the #1 piston sets ---------------------------------------------------later | ||
Expert Posts: 3776 Location: NorCal | 6 225 T 2 6 7 I'll take a stab at it. 6= 1966 225= Displacement T= Built at the Trenton engine plant 2 6= Build date February 6, 1966 7= ? This is usually either a 1 or a 2 to denote what shift it was built on. | ||
56Fanatic |
Expert Posts: 1352 Location: Springville, CA | Why don't you try slant6.org | ||
196061SAVOY |
User has resigned from board | close, but i dont think they made a 5 hole slant 6 in 66, i think the 5 hole began in 68, maybe it was military, maybe it spent some time over in country, i guess we"ll never know . thanks | ||
196061SAVOY |
User has resigned from board | good idea, there is a post already at the slant 6 club, someone else has the same block with same questions i have , i know forward look members are way smarter, thats why i posted it here, no big deal, im over it, i can say its anything, exsperimental 225 slant 6, im sure theres people who will eat that up, thanks again | ||
Chrycoman |
Expert Posts: 1819 Location: Vancouver, BC | 1966 would be the letter "B", but in the 1970's (1974-1978?) Chrysler also used the last number of the model year. Thus "6" would be 1976 (letter "M"). The plant code usually was placed after the model year code, while the letters after the engine size were for variations on the engine (low compression, high compression, regular fuel, truck, size of bearings, etc.) After that usually two groups of four numbers were stamped into the pad. One group was for the date the engine was assembled, based on the 10,000 day calendar, and the other the daily sequential production number which started at 0001. | ||
196061SAVOY |
User has resigned from board | chicago engines , has a listing for a 1975-1978 steel crankshaft 225 truck engine , shows a block casting number of 030-14 , among other block casting numbers, waiting on reply for info on what my block might be | ||
Expert Posts: 3776 Location: NorCal | Chrycoman - 2014-09-27 7:54 PM After that usually two groups of four numbers were stamped into the pad. One group was for the date the engine was assembled, based on the 10,000 day calendar, and the other the daily sequential production number which started at 0001. That's true of the engine serial number which is unique to one engine but the data pad numbers are more typical of those on the OP, could be any one of dozens of engines. You're correct about the year/plant codes...the example in the OP is a '76 not a '66 and is truck rather than Trenton which would be elsewhere in the sequence. So the stamping would decode: 6 225 T 2 6 7 6= 1976 225= Displacement T= Truck 2 6= Build date February 6, 1976 7= ? | ||
Chrycoman |
Expert Posts: 1819 Location: Vancouver, BC | 57chizler - 2014-09-28 4:38 PM Chrycoman - 2014-09-27 7:54 PM After that usually two groups of four numbers were stamped into the pad. One group was for the date the engine was assembled, based on the 10,000 day calendar, and the other the daily sequential production number which started at 0001. That's true of the engine serial number which is unique to one engine but the data pad numbers are more typical of those on the OP, could be any one of dozens of engines. You're correct about the year/plant codes...the example in the OP is a '76 not a '66 and is truck rather than Trenton which would be elsewhere in the sequence. So the stamping would decode: 6 225 T 2 6 7 6= 1976 225= Displacement T= Truck 2 6= Build date February 6, 1976 7= ? The system with the model year code, engine size, date and (sometimes) shift was used starting 1960 (1966 on Canadian-built engines) The engine serial number system I was working with was adopted for the 1968 model year. That number was stamped on the block of the slant six engnie just below the #1 spark plug. Can be hard to read due to the alternator. Both engine number types were stamped in the same locations, so you would find one or the other. The 2 6 7 sequence is probably missing a few digits. On the slant six, the partial VIN was stamped on the engine block just below #6 spark plug. | ||
196061SAVOY |
User has resigned from board | very good, that solves the puzzle, truck/car 225 same thing, no other internal diff, correct, it sure does pull hard off the line compared to my date correct 61 225, probably rear gear ratio has a lot to do with that, thanks again | ||
Expert Posts: 3776 Location: NorCal | Chrycoman - 2014-09-28 4:28 PM The 2 6 7 sequence is probably missing a few digits. If the OP is correct and the 2 6 7 follows directly behind the T and is, as you believe, the build date based on the 10,000 day calendar, 267X would be in mid-November 1968 and 5 digits would have to be missing. On the slant six, the partial VIN was stamped on the engine block just below #6 spark plug. And the build data would be stamped below #1...since the OP only stated "under the head, on the pasenger (sic) side" more info is needed. (or a pic) | ||
196061SAVOY |
User has resigned from board | im pulling the 225 motor out tomorrow, so I will have a better view of any and all numbers , thanks again | ||
