57 dodge booster Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
5geppetto7 |
Member Posts: 13 | I have a brake power booster unit for a dodge 56-64 but no idea how to install or use it, have searched the internet no luck. Its NOS and is manufactured by a company called Kellsey-Hayes. Any help would be appreciated. | ||
mstrug |
Expert 5K+ Posts: 6500 Location: Newark, Texas (Fort Worth) | Read your factory Maintenance Manual. Look at the pictures. Get all the power brake parts that go with your unit at Big 'M' or some other salvage yard. That plate behind your Master cylinder, I think is different, push rod possibly too. Did you get the vacuum tank? Marc. http://www.oldcarsweekly.com/restoration/new-brake-booster-saratoga... Edited by mstrug 2014-09-20 12:48 PM (powerbarkekit1.jpg) (powerbarkekit2.jpg) Attachments ---------------- powerbarkekit1.jpg (15KB - 119 downloads) powerbarkekit2.jpg (12KB - 108 downloads) | ||
5geppetto7 |
Member Posts: 13 | thanks for the info I don't have the tank just rubber booster and MC the plate looks the same though. | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | You need the pedal assembly as well There really wasnt anything that crossed from manual to the power brakes, its all different Sometimes mopar did that to you After the master cyl, everything should be good | ||
ronbo97 |
Expert Posts: 4037 Location: Connecticut | If you're converting a manual brake car to power brakes, you will need the pipe that connects to the vacuum port on the intake manifold. As Mick says, you will also need a power brake pedal assembly. One thing that the OCW article fails to mention is the curved 'finger' on the pedal rod that activates the power assist. If this was bent out of alignment during the removal of the power brake assembly, the power assist will be triggered either too soon or too late. The FSM has a measuring tool that can be copied onto clear acetate and used to measure alignment of the finger. Ron | ||
5geppetto7 |
Member Posts: 13 | Thanks everyone I think MORE research is called for | ||
Expert Posts: 3776 Location: NorCal | 5geppetto7 - 2014-09-20 7:31 AM I have a brake power booster unit for a dodge 56-64 That year span is questionable, many different style boosters over those years. Got a pic? | ||
5geppetto7 |
Member Posts: 13 | It looks just like the one in the photo above but I think I will look a t modifying a more modern brake system on the car | ||
ronbo97 |
Expert Posts: 4037 Location: Connecticut | 5geppetto7 - 2014-09-22 7:33 AM It looks just like the one in the photo above but I think I will look a t modifying a more modern brake system on the car Why go through all that hassle and end up with something that may or may not work ? Converting to power brakes is fairly easy. The hardest part (IMHO) is replacing the brake pedal assembly. Look at a parts book and the service manual and ask questions here. Ron | ||
mstrug |
Expert 5K+ Posts: 6500 Location: Newark, Texas (Fort Worth) | small primmer on install: enjoy! http://www.youtube.com/watch?v=dQ8tZNX8QYQ | ||
