Oil filter adapter question Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
baker53 |
Veteran Posts: 279 Location: Klein, TX | Any thoughts on replacing the original oil filter can on a 325 poly engine in a '57 Desoto Firesweep would be appreciated. I presume the existing oil filter assembly unbolts from the block and a after market adapter is attached to the block. I am hoping someone has already used one of these adapters on a Firesweep and can provide some sage advice. Thanks in advance. | ||
wbower3 |
Walter passed away on Jul 29, 2014. We will miss you, Walt! Posts: 5358 Location: Heaven Above (Formerly Oklahoma City,OK) | Check with HOTHEMIHEADS.com. Their catalogue will give you options on a replacement fitting for screw on-modern filters. I have a Mopar V6 (3600) filter on their vertical adapter on my 271 Hemi, I have to use the smaller filter as the bigger Ferd filter interfered against the bell housing., But the 3600 filter is accessible from underneath and removing it won't spill oil down the side of the engine. | ||
Expert 5K+ Posts: 9650 Location: So. Cal | I don't recommend switching to a modern oil filter without pulling the pan. The motor has a check valve underneath the rear main cap that will allow oil to bypass the filter if there is any back pressure. The new filter design doesn't flow as easily as the older filters and so you will end up with most of your oil bypassing the filter. If you want to swap to a new style filter, it is best to block off that bypass valve too. | ||
Mopar1 |
Expert Posts: 3033 Location: N.W. Fla. | Powerflite - 2014-04-20 9:08 PM Actually it's an anti-drain back check ball. While operating the ball moves up into the passage blocking it except for a small amount of oil that can work around the ball, certainly not enough to oil an engine if the filter was clogged.I don't recommend switching to a modern oil filter without pulling the pan. The motor has a check valve underneath the rear main cap that will allow oil to bypass the filter if there is any back pressure. The new filter design doesn't flow as easily as the older filters and so you will end up with most of your oil bypassing the filter. If you want to swap to a new style filter, it is best to block off that bypass valve too. | ||
Mopar1 |
Expert Posts: 3033 Location: N.W. Fla. | Hot Heads has an adaptor that matches the up angle of the OEM filter. The torsion bars interfere with the verticle filter ones in most cases. | ||
fenix |
Expert Posts: 2119 Location: atlanta | Mopar1 - 2014-04-20 10:46 PM Hot Heads has an adaptor that matches the up angle of the OEM filter. The torsion bars interfere with the verticle filter ones in most cases. uh oh, I hope not. Edited by fenix 2014-04-21 2:33 PM | ||
wbower3 |
Walter passed away on Jul 29, 2014. We will miss you, Walt! Posts: 5358 Location: Heaven Above (Formerly Oklahoma City,OK) | Check with Bob Walker at HOTHEMIHEADS, he has all the answers about the check valve and the fitment of the bolt on adapters and the year model of vehicle! | ||
jimntempe |
Expert Posts: 2312 Location: Arizona | fenix - 2014-04-21 11:31 AM Mopar1 - 2014-04-20 10:46 PM Hot Heads has an adaptor that matches the up angle of the OEM filter. The torsion bars interfere with the verticle filter ones in most cases. uh oh, I hope not. On the plus side, the adaptor will probably be cheaper then the flywheel was.... | ||
Mopar1 |
Expert Posts: 3033 Location: N.W. Fla. | If the one you ordered won't clear, T R Waters on the HAMB has announced one that verticle & doesn't stick out as much, might work. | ||
Expert Posts: 3775 Location: NorCal | The T R Waters unit is adjustable, it can be clocked in any position from vertical to horizontal. https://www.trwaters.com/product/variable-position-oil-filter-mount/ Edited by 57chizler 2014-04-22 2:47 PM | ||
56RoyalLancer |
Elite Veteran Posts: 608 Location: Madison, Wisconsin | John, Would the T R Waters unit work on a 315cid poly? | ||
Mopar1 |
Expert Posts: 3033 Location: N.W. Fla. | 56RoyalLancer - 2014-04-22 4:31 PM Should bolt onto any early hemi/hemi based poly.John, Would the T R Waters unit work on a 315cid poly? | ||
baker53 |
Veteran Posts: 279 Location: Klein, TX | Purchased the 30 degree oil filter mount from Hot Heads and it worked out very well. | ||
JT Vincent |
Expert Posts: 1493 Location: Jamaica Plain, MA | At $71, not a bad investment. | ||
