331 hemi starter motors
ram300
Posted 2013-05-21 11:29 PM (#376431)
Subject: 331 hemi starter motors
1001001002525
Could anybody tell me if the '51-55 331 hemi 6V starters are all identical? I have a very early starter '51-2 which would be from an integral b/housing will this work on a '55 331?
Thanks!
Mopar1
Posted 2013-05-22 5:31 AM (#376457 - in reply to #376431)
Subject: RE: 331 hemi starter motors
2000100025
ram300 - 2013-05-21 10:29 PM
Thanks!
should interchange. 51-6 use 146 tooth ring gear & 51-55 are 6V. '56 is 12V & 146. 57 & up is 12v and172 count
Posted 2018-08-18 11:29 PM (#568620 - in reply to #376457)
Subject: Re: 331 hemi starter motors
5000200020005001002525
I just read some interesting information in a parts catalog. It looks like the 146 tooth Chrysler starters will directly interchange with the '51-'53 Oldsmobile V8 (6 Volt) starters, which also have 146 tooth flywheels. Also, the '57-'58 Chrysler starters with 172 tooth flywheels will interchange with '54-'56 Oldsmobile starters that are even the same 12Volt drive voltage. So that may open up more possibilities if someone can't find an original Chrysler starter for a decent price.
How is this useful? I found aftermarket hi-torque starters for the Oldsmobile that are $60 cheaper than the equivalent Hemi starter, and yet they have the same part number!!
Posted 2018-08-19 4:53 PM (#568647 - in reply to #568620)
20001000500100100252525
What parts catalog? The Hollander Interchange doesn't show an interchange.
60 dart
Posted 2018-08-19 6:11 PM (#568650 - in reply to #376431)
50002000100050010010010010025
whats the number on your 51-52 starter ------------------------------------------------------------later
