A-833 swap, behind a Dodge 230 flatty
Jump to page : 1 2
Now viewing page 2 [50 messages per page]
RICKYMOPAR
Posted 2018-02-14 6:53 PM (#558116 - in reply to #366432)
Subject: Re: A-833 swap, behind a Dodge 230 flatty
100100252525
Not a close ratio transmission. second to third is a large RPM drop.
wayfarer
Posted 2018-02-15 10:34 AM (#558138 - in reply to #558094)
500100100100252525
Powerflite - 2018-02-14 7:51 AM
Why the "A" designation? I always thought that the "A" stood for automatic, as in A727.
Now that is a good question....likely with no discernable answer.....
We might surmise that 'A' does not indicate 'automatic', just something that 'they' thought was needed.
'A' being at the front of the alphabet and 'T' (as in T-10) stuck in the back may have been just a marketing ploy.
MaMopar did sell a handful of 62 RB cars with the T10 but the trans was too weak for the torque monsters and a new design was born.
Now I wonder why Borg Warner uses 'T' ?
56RatKing
Posted 2018-02-15 10:47 AM (#558139 - in reply to #366432)
The "T" in borg warner rigs stands for Transmission - then the ammount of speeds. Aka T-5, T-4 , etc . After they were bought up by tremec they kept the old naming convention for the old parts.
58coupe
Posted 2018-02-15 11:16 AM (#558141 - in reply to #366432)
100050010010025
Mopar also used the T-10 in their 63 models. I have always wondered why you could get only the T-85 3 speed (used as the design basis for the T-10) behind the 62-63 max wedges if you wanted a manual but not the T-10 which was equally as strong. As was previously mentioned not strong enough.
RICKYMOPAR
Posted 2018-02-15 1:00 PM (#558147 - in reply to #366432)
100100252525
A-230 heavy duty three speed, A-390 all synchronized.
wayfarer
Posted 2018-02-16 11:20 AM (#558209 - in reply to #558139)
500100100100252525
56RatKing - 2018-02-15 7:47 AM
T-10 T-85 ????????? Me thinks another system is at work....
jboymechanic
Posted 2018-02-16 2:56 PM (#558219 - in reply to #366432)
2000100252525
The transmission in this setup is a late A body A-833 overdrive from a feather duster. That is why it has the shorty tail housing. I have the same setup in my 1960 Plymouth, but the trans came out of an early 1980s pickup. It has a long, cast iron tail housing but the main body is still aluminum. There are a lot of versions of this transmission, check out brewers performance if you would like to learn more.
The over drive does have a pretty large gear ratio jump between 1st and 2nd, but that doesn't bother me as I'm not racing. The little hemi and the 318 poly should both have plenty of grunt to handle the drop in RPMs. After all, the old slant six could do the job as well.
RICKYMOPAR
Posted 2018-02-16 9:48 PM (#558234 - in reply to #366432)
100100252525
You have done a great job. Thanks for the information related to such a swap.
jboymechanic
Posted 2020-10-20 10:33 PM (#604717 - in reply to #558234)
2000100252525
Well, it's a few years late, but here is a .dxf file of the adapter plate I used to adapt the A833 4 speed (overdrive version) to the original bell housing. Download this file and provide it to a metal fabricator with a laser table and they can cut this out for you if you want to try it.
Attachments A833 adapter.DXF (61KB - 279 downloads)
Posted 2020-10-21 12:36 PM (#604735 - in reply to #558147)
200010005001001002525
RICKYMOPAR - 2018-02-15 10:00 AM
Other way around, A-230 is all synchro. Recently swapped one into my '57 wagon.
As to the strength of the T-10, my '63 Dodge was originally a 383-4 with the T-10; I swapped in a 426 Max Wedge and ran it quite a while that way with 7" tires (limited traction) but later managed to get an A-833 and installed it.
Posted 2020-10-21 12:57 PM (#604737 - in reply to #366432)
50002000200050010025
Thanks for the adapter plate design Jon. I recognize the hole positions that I circled in red as being used by the 4-speed. But my '56 3 speed bolt pattern uses more of a square pattern with one extra bolt on one side. So what transmission, specifically, does this work for?
(4Speed Adapter.jpg)
Attachments 4Speed Adapter.jpg (32KB - 270 downloads)
jboymechanic
Posted 2020-10-21 1:40 PM (#604738 - in reply to #604737)
2000100252525
I believe the "heavy duty" 4 speeds in the trucks in the mid to late 1950s was the NP420.
Posted 2020-10-21 2:34 PM (#604744 - in reply to #604737)
Powerflite - 2020-10-21 9:57 AM
Doesn't the name on the .DXF file say it all? A-833 (aka NP-440)?
REFERENCE: https://www.hemmings.com/stories/article/chryslers-a-833-np-440-four...
jboymechanic
Posted 2020-10-21 4:39 PM (#604756 - in reply to #604744)
2000100252525
To clarify, the adapter plate allows you to mount an A833 4 speed in place of what I believe to be a NP420 4 speed.
jboymechanic
Posted 2022-07-06 9:56 AM (#622678 - in reply to #366432)
2000100252525
I'll have an update soon for this engine to trans combo. If you watched the video, the hemi was pretty smoky. We bought a radiator and new water pump and we're looking to run this engine up to temperature for an extended period so we can see if the rings seat or re-seat. We are also working on a lever to actuate the clutch so we can test out the trans and shift through the gears.
jboymechanic
Posted 2022-07-11 4:20 PM (#622813 - in reply to #622678)
2000100252525
Here is the little 241 running on a test stand. The oil is old and thin, it was at 45 psi when cold but continued to drop as it warmed up. Good news is that as the engine ran, the vacuum increased and the oil smoke decreased. We're going to change the oil and keep running it while keeping an eye on it.
https://www.youtube.com/watch?v=5gZFju31rnw
Jump to page : 1 2
