Gear Reduction Starter
Fred
Posted 2013-02-24 7:51 PM (#361685)
Subject: Gear Reduction Starter
I installed Clifford headers on my 1961 Dodge Dart Pioneer wagon and needed a reduction starter to since the original direct drive starter would not fit. I ran a modified late model starter at first, but the shop that modified it said that the metal was machined pretty thin so I decided to look for a purpose-built unit. RobbMC makes starters for niche models and since he had a hemi starter I asked him about making a unit that would fit on my car. It took a while to work out the details but I put the starter in a couple of week sago and so far it starts like a charm every time. The cost was high - about $350 but I decided that if I avoided one tow I was ahead of the game.
(RobbMC starter -1961 slant 6 A904 auto.jpg)
Attachments RobbMC starter -1961 slant 6 A904 auto.jpg (241KB - 587 downloads)
mogge65
Posted 2013-02-28 11:02 AM (#362363 - in reply to #361685)
Subject: Re: Gear Reduction Starter
1000100100252525
clifford headers???? could you give us more info and pics please! Nice set up with the starter............
jboymechanic
Posted 2013-05-10 5:23 PM (#374557 - in reply to #361685)
2000100100
$350 isn't bad, pretty sure a paid that for an off-the-shelf light weight high torque starter for my 354 Hemi.
Beltran
Posted 2013-05-10 7:48 PM (#374575 - in reply to #361685)
100050010010025
I used this. Works great and much less expensive. http://www.hothemiheads.com/transmission_adapters/starter_light_wei...
GregCon
Posted 2013-05-13 4:23 PM (#375025 - in reply to #361685)
Does that Hot Heads work with a stock tranny? It says it works with HH adapters.
Beltran
Posted 2013-05-13 7:43 PM (#375051 - in reply to #361685)
100050010010025
Yes. It does, I have it on my 56 PF. Bolted right in without issue. Nice thing is you can turn the motor and solenoid so it can be in almost any position depending on your headers and what you need.
(Starter1.jpg)
(starter2.JPG)
Attachments Starter1.jpg (58KB - 521 downloads)
Attachments starter2.JPG (166KB - 647 downloads)
GregCon
Posted 2013-05-13 10:14 PM (#375098 - in reply to #361685)
So is that starter any different than the usual Mopar min-starter? Does it use some sort of adapter plate?
Beltran
Posted 2013-05-14 10:32 PM (#375274 - in reply to #361685)
100050010010025
It might be the same. I am not sure. I did not have to purchase anything else but the starter. The mount is adjustable and that is the only 'adaptor' it has as part of the housing.
GregCon
Posted 2013-05-21 11:41 AM (#376305 - in reply to #361685)
Subject: RE: Gear Reduction Starter
I talked to Hot Heads....their mini-starter that is $145 will fit some FL cars but not others. Apparently the 'bigger and later' Hemi's went to a 172 tooth ring gear and that will not work with the $145 starter. They do sell one that does work but it is $290.
jboymechanic
Posted 2013-05-23 9:37 PM (#376819 - in reply to #361685)
2000100100
That makes sense. I have a 172 tooth torque converter from a 392 Hemi behind my 354, would explain why I didn't get off so cheaply.
Posted 2014-02-26 11:50 PM (#429140 - in reply to #376819)
50005000100100100252525
Looking at the Hot Heads site, I see a remanufactured starter that is supposed to work with '57-'59 for $95. It looks just like the standard Dakota starter, but there are 4 parts sitting next to it. Does anyone know what the difference is here to make a Dakota starter work on the '57-'59 and what those small parts are for?
Edited by Powerflite 2014-02-26 11:51 PM
(29183.jpg)
Attachments 29183.jpg (3KB - 460 downloads)
60 dart
Posted 2014-02-27 12:05 AM (#429142 - in reply to #361685)
Expert 5K+ Passed away 30th Sept 2024. You will be missed Chuck!
5000200010005001001001001002525
ok , but fred , isn't the little tube on top supposed to be on the bottom --------------------------------------------------------later
Phil_the_frenchie
Posted 2014-02-27 5:01 AM (#429156 - in reply to #361685)
50010010010010025
I post a message some months ago http://www.forwardlook.net/forums/forums/thread-view.asp?tid=49106&...
Shep
Posted 2014-02-27 2:48 PM (#429197 - in reply to #429142)
20001000100100100100252525
60 dart - 2014-02-27 12:05 AM
Correct, drain tube on bottom.
Posted 2014-02-27 3:03 PM (#429200 - in reply to #429197)
200010005001001001002525
The RobbMC starter is designed so that the solenoid can be rotated to clear obstructions, in some positions the
"drain" tube won't be on the bottom.
BigBlockMopar
Posted 2014-02-27 4:10 PM (#429206 - in reply to #361685)
20001000500252525
Fred - 2013-02-24 1:51 PM
... and so far it starts like a charm every time. ...
Fred, with the way those wires are crimped and hanging around there that probably won't be for long...
That $350 starter deserves some proper connections.
mopark
Posted 2014-04-10 11:02 PM (#435431 - in reply to #361685)
Hi, Could some one tell me what geared starters fit the 1959 Dodge  361 with the torque fight 3 speed auto. Thanks in advance
canyouheminow
Posted 2014-04-15 1:29 PM (#436204 - in reply to #435431)
The one gear reduction starter early in this post is made by powermaster.They make them for 146 tooth and 172 tooth flywheels.
there email for tech and questions is tech@powermasterperformance.com. http://www.speedwaymotors.com/Powermaster-9531-1957-58-Hemi-Gear-Re...
Posted 2024-07-02 8:13 AM (#635940 - in reply to #361685)
Btw.... these power master servers will be in the way, the center link will hit and stop on the starter when you turn hard left on a 392 hemi fitted into a Dodge(its a half inch short to hit the stop at the hub).... I assume it's the same with a Plymouth and possibly others.
I'm experiencing this right now.
