56 Dodge Royal 315 Super Red Ram fuel pump
58 300D
Posted 2012-08-14 4:59 PM (#334608)
Subject: 56 Dodge Royal 315 Super Red Ram fuel pump
5002525
I am failing in finding a fuel pump for my 56 Royal with the Super Red Ram 315 poly. Any suggestions?
Thank you,
Matt
Brushwolf
Posted 2012-08-14 6:17 PM (#334617 - in reply to #334608)
Subject: RE: 56 Dodge Royal 315 Super Red Ram fuel pump
100100252525
I got a kit from Egge Machine in CA and rebuilt mine, although mine is a 57 325 hemi I suspect they are similar. They need number stamped into mounting flange of your old one to figure out what kit you need. Other alternative is to get adapter from Hot Heads that will allow you to run a later pump.
Here is link to part: http://hothemiheads.com/dodge/cam_shafts_timing/fuel_pump_adapter.h...
d500neil
Posted 2012-08-14 7:44 PM (#334625 - in reply to #334617)
Subject: Re: 56 Dodge Royal 315 Super Red Ram fuel pump
500050005000200020001002525
I would get the rebuild kit, as it will accommodate ethanolic gasoline.
Egge is a good Old School company.
jim's56
Posted 2012-08-14 8:06 PM (#334635 - in reply to #334608)
I have a 315 engine in my 56 dodge. I am considering installing an electric fuel pum
p and blanking off the hole in the timing chain cover.
d500neil
Posted 2012-08-14 8:23 PM (#334638 - in reply to #334635)
Electric fuel pumps have burned down many a car, over the years, by continuing to pump out fuel onto a manifold (usually)
area leakage.
Mopar1
Posted 2012-08-14 10:07 PM (#334655 - in reply to #334638)
20001000
Another option is a Hot Heads adaptor & an LA F/P.
58 300D
Posted 2012-08-15 9:44 AM (#334712 - in reply to #334617)
5002525
Sweet, I will get a hold of Egge today. My pump looks great and works, but this weekend it was beginning to fail and cut out at highway speeds. The fuel lines are clean and clear, the tank is full, but the pump is the original and must not like being used regularly after sitting idle since the late 70s.
Thanks again,
Matt
d500neil
Posted 2012-08-15 4:16 PM (#334744 - in reply to #334712)
For everyone else: the easiest way to check on your car's fuel pump health is merely to get it up to about 30-40,
and then to floor the loud pedal, and keep it there for a while---this can be a fun exercise.
A weak or failing pump will cause the engine to stumble or to surge, due to intermittent fuel supply.
No stumbling/faltering: yer gud 2 GO..."but, officer, I was just checking my car's fuel pump operation!"
t2dfyre
Posted 2012-09-01 6:48 AM (#337121 - in reply to #334608)
10010010025
Carter fuel pump from summit will work. Thats what i replaced mine with and i have the same motor. I did have to purchase a fuel regulator...all in all it was about $100 for everything and got it the next day.
